Old 05-03-2010, 11:08 PM   #1
TC3ElectricGuy's Avatar
Default running in engine - question
ok. starting to run in my engine and i'm onto the 2nd tank.
the tank was about 1/2 used. prob 8 minutes of running at a fast idle...
all of a sudden the revs jumped enormously. i have the power off so i adjusted the throttle position to what would be the closed position.
but the revs kept climbing. i had to shut the engine off before i did damage to the engine..
what may have caused this, and any help would be appreciated.
Team Losi 8ight 2.0
Axe Cobra X1 Evo .21 engine
Axe 2050 pipe
TC3ElectricGuy is offline   Reply With Quote
Old 05-03-2010, 11:32 PM   #2
NitroNewbie's Avatar
Trader Rating: 19 (100%+)
Did you adjust the idle to keep it running? If so this is what caused it as the carb was closed but the idel gap was adjusted to far for it to drop to normal.
NitroNewbie is offline   Reply With Quote
Old 05-03-2010, 11:47 PM   #3
yeah, let it be known, i'm just an idiot. lol.
without swearing on this site..... it was leaning out as it ran out of fuel.
Team Losi 8ight 2.0
Axe 2050 pipe
Old 05-04-2010, 07:35 AM   #4
Frank L's Avatar
Trader Rating: 148 (100%+)
Does your engine have a middle needle? I had a vspec speed that the middle needle was turned all the wY in and it did exactly what you are describing. Idk howthT needle got adjusted like that but I richened it up andnproblem solved.
Old 05-04-2010, 07:44 AM   #5
jammin32j's Avatar
Chech your fuel line in the tank. It could have gotten a hole in it. Also make sure your pressure line is OK too.
VP Pro, Agama
Hitec-7955's, 3Pk----AKA Racing Tires
Absolutehobbyz.com____Dirtrc.com
O'Donnell, D.I.R.T. R/C ultimate Tire Gluer
Jeremy Davis
jammin32j is offline   Reply With Quote
Old 05-04-2010, 08:10 AM   #6
jbright33's Avatar
Trader Rating: 14 (100%+)
Send a message via AIM to jbright33
just sounds like its high idle and top end lean causing it to rev
JESSE BRIGHT
jbright33 is offline   Reply With Quote
Old 05-04-2010, 11:55 AM   #7
Roelof's Avatar
Send a message via ICQ to Roelof
It did become to hot causing less pinch on the piston (which will go faster) and an early combustion.
Also on idle you have to use a rich setting for lubrication and cooling.
The quality of an answer comes with the quality of the question.
Roelof is online now   Reply With Quote
nitro engine running in reverse? xbonggoox Nitro Off-Road 18 10-01-2015 03:00 PM
Engine question for all you onroad guys! SavageSYNTH25 Nitro On-Road 8 01-09-2006 02:23 AM
Is the number of ports in engine really tied to performance? jasoncsc Onroad Nitro Engine Zone 7 05-09-2004 12:08 AM
Serious gas engine question. pro engine tuners look here Ron Nitro On-Road 28 11-13-2001 04:27 PM
