Old 05-03-2010, 08:37 PM   #1
Default I need more steering with my rc8
I have an rc8 rtr and I can't get it to turn near as sharp as some other buggys i've seen. What are some changes I can make that will make it so I can turn sharper? I don't want to buy anything, I just want to make adjustments with what I have.
I'm also bottoming out really bad on one of our home tracks on the big jumps. Would switching from the 1.6mm shock pistons to the 1.4mm ones help this and not make me bounce all over the place.
The track with the big jumps is very smooth, but the other track has some major ruts all over it.
bevofrancis is offline   Reply With Quote
Old 05-03-2010, 08:42 PM   #2
Shoaf85's Avatar
Trader Rating: 19 (100%+)
What are some more details on your set up? Is your RTR new enough to have the updated steering (steering mod) on it? Give a little more set up info and I'm sure someone can get you going in the right direction!
Team AE all the way...
FASTLANE GRAPHIX !!!!!!!!
Shoaf85 is offline   Reply With Quote
Old 05-03-2010, 11:18 PM   #3
merdith6's Avatar
Default remove the
Swaybar in the front. Just an idea....
Mad Dog drives a Mugen MBX-7, Novarossi engines, Clockwork Racing, Futaba radio, AKA/Proline Tires
merdith6 is offline   Reply With Quote
Old 05-04-2010, 03:43 AM   #4
It's only about 2 months old, but I don't think they do the steering mod on the RTR's. I think that's just on the rc8b's. Really the only thing I have done to it, is I moved the battery up front, and put some decent tires on it.
Old 05-04-2010, 04:24 AM   #5
Shoaf85's Avatar
What shock oil are you using? I know you said you didn't want to buy anything but the steering mod really adds a good bit of steering to the car!
Old 05-04-2010, 04:38 AM   #6
I don't run AE, but I would try lowering the front and/or raising the rear ride height a little. Also try dialing in a little more rear brake bias. Those are simple things to try at the track. I don't know what you're running for diff set-up either, but going a lower in the front and center will give you more off-power steering.
Shaun Davis
VP ProUSA
Mugen Seiki/Alpha Engines
Team Trinity
Miniracer23 is offline   Reply With Quote
Old 05-04-2010, 05:06 AM   #7
JoeyTheRocket's Avatar
Send a message via AIM to JoeyTheRocket Send a message via Yahoo to JoeyTheRocket
This is where all the info is at. Team Associated 1/8 scale Buggy Info and Tips
Setup I would throw this in your car and then tell us what you do or donít like. This is what most of us run. http://67.199.85.166/racing/setups/r...lenge_2010.pdf
Joey Kubat ↔ MWNS Staff www.MidwestNitro.com
Mugen Seiki / AKA Racing / Novarossi / PT RC Racing Oils / Advantage Racing Products
JoeyTheRocket is offline   Reply With Quote
Old 05-04-2010, 09:43 PM   #8
dunnyrc51's Avatar
Check your steering endpoint adjustments and make sure they are set right with your radio and servo.
Try changing the caster bushings to the 14's. This helped mine big time!
As for your shocks its hard to say with the RTR shocks. Most guys ran the emulsion shock set up before they had the big bores. But the big bore shocks are the way to go. Other than that check your ride hieght, around 28-29mm I think. You can try stiffer shock springs or thicker shock fluid.
How does your car jump with the current set-up. Is it nose high or down? Do you have to throttle or brake it in the air?
Also its better to set-up your buggy for 80% of the track and not just one part or jump of it.
"You cant win a race when your buggy is on its lid"
dunnyrc51 is offline   Reply With Quote
need some help with picking a buggy constantinos Nitro Off-Road 30 10-07-2009 08:49 AM
NEXT GENERATION RC8.0 BUGGY alexzone007 Nitro Off-Road 39 03-16-2009 07:28 PM
RC8 Factory Team vs MBX 6 need some feedback robbdny Nitro Off-Road 79 12-14-2008 10:37 AM
