Old 05-02-2010, 07:52 PM   #1
Default Nitro Buggy Help
I need help with my nitro buggy. I can get it fired up, but it tends to die easily right after it starts. Also, it kindof bogs down on the top end and doesn't seem to run as fast as it should.
What should I do? I'm guessing tune but I'm new to that sooo please explain
Also, a side note, a few times I have run it, the motor will be warm (I can hold my hand on the engine head a few seconds before it gets hot) but there will be smoke coming out of the engine head. I'm guessing thats not good?
Thanks,
Rob
supamagician is offline   Reply With Quote
Old 05-02-2010, 08:01 PM   #2
Bengsch85's Avatar
First of all read the tuning bible thread at the top of the forum for everything you need to know about tuning. Now is it a bog like a gurgling type sound or does it seem to just run out of fuel on the top end? And your engine wont be running properly if its not up to temp which is over 200 so you cant hold your hand against a properly warmed up engine.
D8T/Werks B5~~~~OFNA 9.5/Picco P3 B~~~~TTR ST1/Jammin JPL.28
Savox/Spektrum/Odonnell Fuel
Team Terribles www.teamterribles.com
www.clarkrcpark.com
We are always looking for more racers at the track!
Bengsch85 is offline   Reply With Quote
Old 05-02-2010, 09:30 PM   #3
when I start it up and it dies it just stops. no gurgle, no nothing just stops. When it shuts off on the top end, it bogs
Old 05-03-2010, 07:57 AM   #4
Sounds like your too rich on the low speed needle, causing the engine to flood. And too lean on the high speed causing the engine to bog.
one8updragracer is offline   Reply With Quote
Converting 1/8 scale nitro buggy HELP WANTED rcCrafty Electric Off-Road 6 02-04-2010 03:43 AM
temporary AM radio for 1/8 nitro buggy....will i be safe?? pwnzor Nitro Off-Road 49 06-30-2008 09:25 PM
RCAC 1/8 Nitro Buggy Off-Road Club Race - 16th December 2007 bgdesmoulin Malaysian R/C Racers 36 12-14-2007 01:13 AM
