Old 05-01-2010, 07:05 AM   #1
Show871's Avatar
Default Fuel tubing on the brake linkage adjustments
Could someone explain to me the technics behinds adjusting the fuel tubing on the brake linkage. I understand why its there, but is there a big difference in adjusting the length, and different styles of tubing? Is breaking sensitive to these adjustments? 2.0 buggy
Thanks 871
Show871 is offline   Reply With Quote
Old 05-01-2010, 10:19 AM   #2
The tubing allows variable brake application easier. Shorter tubing will make the brakes harder to modulate, it will be like an on/off application almost. Longer tubing will make them more progressive through range of servo travel. On a 1:1 car it's like having a spongy brake pedal with lots of travel vs one with a very firm pedal, spongy pedal (long tube) you have to move farther to get braking increase, firm pedal (short tube) you just have to increase the force instead of moving as far. I prefer the longest I can use to make brake control easier. Too long will not allow full release nor adequate braking, it's a balance thing for sure. Take them out and put washers or solid tubing in place of it if you want to see an extreme example of it's effect. That would be hard on servo gears though .
Wrencher is offline   Reply With Quote
Old 05-01-2010, 11:03 AM   #3
j_blaze14's Avatar
Trader Rating: 34 (100%+)
i don't like the fuel tubing, i use the throttle springs instead, way more progressive and on/off too if necessary.
aGama A8 EVO - Werks B2 - Sidewinder
aGama A8E - TrackStar 150a, 2560kv, 3 and 4 cell
FlySky GT3B, Turnigy HV servos, SKY Lipos
AKA, Proline, Hotbodies Rubber
Elite Performance - HORRC.com
j_blaze14 is offline   Reply With Quote
Old 05-01-2010, 02:54 PM   #4
terribleswiss's Avatar
ive used fuel tubing in the past but switched to springs. like blaze said, they are more progressive. the brakes just feel better with springs.
kyosho with novarossi power
terribleswiss is offline   Reply With Quote
Mugen MTX-3 university_dave Nitro On-Road 17237 12-30-2012 12:16 PM
Trinity G4 - Team Magic G4 E-Type puma1824 Nitro On-Road 3128 10-04-2005 04:17 AM
