Old 04-29-2010, 07:11 PM   #1
Default How the %^$# do you get the clutch back on!
Losi 8ight t 2.0. Dynamite max life...2 silver springs and 2 gold springs. How do you get the shoe/spring/screw to all line up!!! I just can't line up to get in the last hole on the flywheel. Help!
bacchus is offline   Reply With Quote
Old 04-29-2010, 07:29 PM   #2
Gotta love youtube.
http://www.youtube.com/watch?v=SYQXuJAwkVY
Old 04-29-2010, 07:35 PM   #3
JAMMINKRAZY's Avatar
Trader Rating: 17 (100%+)
Sharpening/rounding the screw helps a lot. If you are using hard springs, sometimes it can still be a pain. I personally have used a large ziptie tightened down around the shoes to compress the springs. Then the screws just go right in.
-Koby Kubrin-
Thanks to my Sponsors:
Serpent America | Team Novarossi | Desoto Racing | Race AKA | Ridgeway Bodies
JAMMINKRAZY is offline   Reply With Quote
Old 04-29-2010, 09:19 PM   #4
Eagle7's Avatar
Trader Rating: 25 (100%+)
Default How I fixed it
http://www.absolutehobbyz.com/produc...oducts_id=1503
MBX7T-Werks B5-2013. MBX7T Eco
MBX7r-Werks B6-2058 MBX7r Eco
TLR 22 2.0 & 22 2.0T
Werks Racing
Eagle7 is offline   Reply With Quote
Old 04-29-2010, 10:46 PM   #5
bobbyblaze's Avatar
Send a message via Yahoo to bobbyblaze
i learn this from dion @ battlefield rc when i had the same problem ..put shoes & springs on then wrap it with a zip tie til tbe holes line up
Arrma Nero 6s, Ofna DM-1 Pro
Traxxas Revo 3.3, Traxxas T-Maxx 3.3, Traxxas Jato 3.3
Traxxas Slash Platinum, Traxxas Slash 2WD
Bend The Rules--Rule The Bends
bobbyblaze is offline   Reply With Quote
Old 04-29-2010, 10:56 PM   #6
DiaRh34's Avatar
Send a message via AIM to DiaRh34
wow I cant wait to try that zip tie trick now
Taco
Bullet Town raceway Milan, Tn
TLR 8b - Tekin - SMC
DiaRh34 is offline   Reply With Quote
Old 04-30-2010, 06:47 AM   #7
Just push the lower part of the shoe in with a finger, its not hard....
TLR - Spektrum - Horizon - TLR 8ight 4.0 - TLR 8ight-T 4.0 - TLR 22 4.0 - Orion
token is offline   Reply With Quote
Old 04-30-2010, 07:51 AM   #8
Insert the clutch pin and with your hex wrench inserted in the clutch pin (as if you are ready to tighten the clutch pin in but dont yet) rotate your hex wrench in a small 360 degree circle while keeping the tip of the wrench in the pin.....this will cause the tip of the clutch pin to do a small circle and it will find the hole....you will be amazed how well this works and it will save your fingers some pain from pushing on the shoes.
catchinup is offline   Reply With Quote
Old 04-30-2010, 08:33 AM   #9
becarful cause when your bending the hex hole on the screw, you can stretch the hole out which will make it possibly strip out.....
Old 04-30-2010, 08:39 AM   #10
Yup...do it carefully, dont use alot of force.
Old 04-30-2010, 10:25 AM   #11
bobbyblaze's Avatar
zip tie method is easier once sit the springs , shoe and the screws in...pull the zip tie and watch the screws fall into place...no bending or striping
Old 04-30-2010, 10:41 AM   #12
+1 I've been using that trick for a while.
-Koby Kubrin-
Old 04-30-2010, 10:42 AM   #13
Originally Posted by Eagle7 View Post
This is how I fixed the problem.
http://www.amainhobbies.com/product_...-Clutch-System
-Koby Kubrin-
What do you guys think of this Werk's .21 Engine? Garet Jax Nitro Off-Road 82 07-20-2016 04:40 AM
What is the best race of the year? (In General) token Nitro Off-Road 58 12-20-2009 09:46 AM
T4 How do you know? oldandnew Electric Off-Road 11 05-20-2009 06:35 AM
Blue Grove or Loomy Which Do You Prefer bluer322 Nitro Off-Road 38 06-20-2008 02:08 PM
