Old 04-29-2010, 10:11 AM   #1
gholt13's Avatar
Default novarossi bf21 limted
anyone ever trided the extech big boy pipe?
RC8B/RC8TLE/
gholt13 is offline   Reply With Quote
Old 04-29-2010, 10:56 AM   #2
jmaxey51's Avatar
if you have one then just try it one day and see. but i would not buy one of those, i have seen them come apart alot. but like i said if you have one try it, but i think thats a bottom end pipe, and that engine need a mid to high end pipe. i personally like the Dynamite 053 pipe on mine.
jmaxey51 is offline   Reply With Quote
Old 04-29-2010, 01:24 PM   #3
most everyone will tell you to run a 9886 or 086 (same thing different manufacturers). as for the bigboy pipe, it is fragile like the guy above me said.
C.Harper is offline   Reply With Quote
Old 04-29-2010, 10:06 PM   #4
Trader Rating: 22 (100%+)
The big boy is a mellow all around pipe. Its not a bottom end pipe at all. It actually is a bit weak on the bottom and even mid but has good top end. It is great for engines that have a ton of power to smooth them out. or give engines that are gas hogs some more runtime. its meant to be smooth everywhere.But its not a power pipe. Ihave only used dit only Werks and sirio engines so not sure how it would work on anything else.. Its a a bit cheap though. Sirio version is way better built.
heidmann1 is offline   Reply With Quote
Old 04-30-2010, 07:08 AM   #5
losiracer78's Avatar
The 086 header and pipe is the best set up for the 21bf hands down
Screen Names Has Changed To mayhem04
losiracer78 is offline   Reply With Quote
Old 05-02-2010, 08:39 PM   #6
voodoopapa's Avatar
I've just purchased one of these to run in my AE RC8B. I find it strange that the carby has to be put in reverse.
voodoopapa is offline   Reply With Quote
Old 05-02-2010, 08:47 PM   #7
jmaxey51's Avatar
what do you mean? you can take the carb off and flip it if you mean the throttle is on the wrong side.
Old 05-03-2010, 12:28 AM   #8
voodoopapa's Avatar
yeh that's what i mean. I just find it strange that the nova sign is now facing the engine and the idle screw is in a position that makes it little difficult to get to especially when the pipe is hot.
Old 05-03-2010, 08:41 AM   #9
jmaxey51's Avatar
all carbs are like that on most engines now. my JPX 21 is even harder to set the idle.
