Changing the color of wheels?
Just put the die in the water, make sure its at least a stainless steel pan or something you dont car about ruining (if its stainless steel it will wash right off)
Thats... it.. pretty simple.
BTW if you want them red, they might turn out a dark orange, usually its kind of hard to go from a bright color to a slightly darker color. Blacks the easiest cause you dont have to time each wheel to make sure its the same shade.
ALSO: make sure there rinsed and cleaned before you die, that can alter the color if the release agent is still on new rims.
RIT Dye is awesome. Just get a big ole pot....boil the water then flip it to low. Drop in the dye...then the rims and let it sit. When I did a set of red it took @ 25-30 minutes to get the color I wanted. When I did Black....I just left em in there for like 2-3 hours to get em nice and black...I mean they couldn't get any DARKER than black right? They stayed purple for quite awhile.
Just make sure you do all the wheels at the same time or you will get different colors and such....
