Old 04-28-2010, 05:39 AM   #1
RoosterXp's Avatar
Trader Rating: 66 (100%+)
Questions?? Low speed needle tuning?
Hey guys, i have a .28 Jammin JPX engine 3/4 gallon through it with a RB 2045 pipe and RB header. I run 30% sidewinder fuel and a O.S. P3 plug. heres whats going on: the engine starts pretty good, it has pretty good power on the top end-good smoke and head temps around 220-240. when it goes from idle to full throttle, i get a huge clould of blue, it seems to rev up alright though.
My other observation- I was setting my low speed needle, i feel like im either getting it too rich or too lean. With the settings i have on it now when the engine is at normal operating temps a lot of the time when i try to let it idle for more than 5 seconds it will stall. also i have noticed that after a few high speed passes and then let it idle, the idle will be a little high then settle down after about 3 seconds stay at a lower RPM idle for a few seconds then stall. also what i have noticed too is that if i lean out the low end to help with the idle, i run my car about 1/4-1/3 throttle for about 3 seconds and let off it stays at that rpm (rpm @ 1/4-1/3 throttle) or maybe a tick under until i hit the brakes.. then if it richen it up it wont stay at that rpm it will go back to idle.. I know its not my servo.
im stumped?!
...to you it's a 6 pack, to me it's a support group.
RoosterXp is offline   Reply With Quote
Old 04-28-2010, 06:30 AM   #2
vti-chris's Avatar
1) make sure that the servo linkages and transmitter EPA are set right with a little gap on the throttle linkage before it actually begins to throttle up after you apply it from the transmitter
2) make sure that the servo throttle linkage moves freely in the plastic hole of the servo arm
3) to me it sounds like a bit too rich on bottom
lean it a bit and lower your idle if it holds high idle
The #3 only if the 1-2 are set right.
If otherwise you need to retune.
Xray/OS/Savox/Sanwa
Axial XR10
Sakura Zero S/Castlecreations
RCO
vti-chris is offline   Reply With Quote
Old 04-28-2010, 07:56 AM   #3
Twitchy Kanai's Avatar
Send a message via MSN to Twitchy Kanai
If you lean (turning it clockwise) the LSN you also have to decrease the idle gap.
KO Helios C2 with Spektrum Pro
Kyosho MP9: TecnoPower, Werks 2013, JR 9100S, JR 9100S
Kyosho ST-RR: RB Concepts WS7II 3X, Werks 2013. JR 9100S, JR9100T
Twitchy Kanai is offline   Reply With Quote
Old 04-28-2010, 08:50 AM   #4
RoosterXp's Avatar
maybe i am adjusting it too much... I miss my RB
can a to rich high speed needle dreaux Nitro Off-Road 51 05-05-2010 06:16 AM
Engine Tuning 101 (General Tuning) Kemorc Onroad Nitro Engine Zone 41 11-19-2007 06:04 PM
Low-speed too rich? sstupid Onroad Nitro Engine Zone 6 03-27-2006 09:08 AM
3 Needle Tuning Zizu Nitro On-Road 16 12-06-2003 09:59 PM
