spur gear help
spur gear help
is it better to have a steel gear or a plastic one
thanks
thanks
bump someone help me because i need to buy buy a new one asap
electric or nitro? If electric stick with plastic. if nitro steel. When you ask a question be sure to give a little info on your application. It makes it easier to answer your questions. Also give the readers time to read and answer before you bump a thread.
and it a nitro (t-maxx 2.5)
so nothing bad will happen to my trany with the steel gear
THANK YOU so much that's what i needed to hear that's why i did not want to get the steel gear
I agree, keep using a plastic spur gear if you have plastic gears in your tranny. If you choose to have a metal spur gear, be sure to use metal gears in your tranny aswell.
