Old 04-28-2010, 09:17 AM   #16
dnebout's Avatar
Trader Rating: 32 (100%+)
A good board to use is a piece of Formica shelving. Very straight and durable. You can even pencil lines and notes on it and erase them later. I threw a piece of 16gauge angle on one end for a wheel stop. Works good just as good as my Hudy I had and that's why I sold it.
Losi 8T 2.0, Werks B5 Pro, Savox 1267 / Hitec 7950
Losi Eight 2.0, Nova 4c, Hitec 7940 / Hitec 7955
Losi Eight E 2.0, RX8, Tekin 1900kv / Hitec 7955
Blackjack 26
Aka: Deebo, Poppa Pump / Busted Knuckle Wheelin' / Henchmen Racing
dnebout is offline   Reply With Quote
Old 04-28-2010, 10:42 AM   #17
Stubbs's Avatar
Trader Rating: 57 (100%+)
Originally Posted by RC-ZOMBIE View Post
can you please post pic?
Here you go... Sorry for the crude sketch, but I'm in Chicago for work at the moment, and my Truggy is at home.
Remember, when using this method, each wheel is half of the total toe (i.e. if you want 2.0 deg. of toe, each wheel is 1.0 deg.)
(Edit - after further research, the statement above applies to full size cars only. For RC, if you want 2.0 deg. of toe, set each wheel to 2.0 deg).
Mike Stubblefield - www.capefearraceway.com
"If you're not racing to have fun, then you're doing it WRONG."
"All you need is WD-40 and Duct Tape. If it moves, and it shouldn't, use the Duct Tape. If it doesn't move, and it should, use the WD-40."
Stubbs is offline   Reply With Quote
Old 04-28-2010, 10:53 AM   #18
RC-ZOMBIE's Avatar
Thanks, and your drawing is great!
Associated~Tekno~Mugen
RC-ZOMBIE is offline   Reply With Quote
Old 04-28-2010, 10:53 AM   #19
Akhor's Avatar
I have one and LOVE it. It gets your vehicle to 100% ready, and takes all the guess work out of all setup issues.
--Blaine--
VBC D07, VBC D08
Mugen MBX 7, Mugen MBX 7 Eco,Mugen MBX 7r, Mugen MBX 7r Eco
www.rcgears.net, www.carcar.ca, www.karz.ca
Akhor is online now   Reply With Quote
Old 04-28-2010, 12:32 PM   #20
ScottyM's Avatar
Trader Rating: 27 (100%+)
No need to eyeball toe....that RPM camber gage works good for that too. Just get a piece of 1 x 4 long enough to extend about 4" past each wheel. The turn your radio on, make sure the servo is centered, and push the 1 x 4 up against the back edge of your front tires. You can then lay the camber gage on its side, put the bottom edge against the wood, and measure toe angle like you would measure camber.
Once you do it a couple of times, it gets really easy. The trick is doing it with the power on, otherwise your servo keeps moving all over the place, and you can't get an accurate reading. Let me know if you need any further explanation...maybe I can post a picture if any of this sounds confusing.
Makes total sense and I was thinking of making up a set up board with something like that incoorperated..
Scott Musgrave
ScottyM is offline   Reply With Quote
Old 05-25-2011, 04:24 AM   #21
Jake C6R's Avatar
This is a great idea! I wish I would have thought of it! I have the RPM toe gauge but it doesn't work all that great on my monster trucks or the 8ight-T but the camber gauge trick looks awesome! I will definitely try this out since I already have that gauge also - it looks like it will be much more accurate than the toe gauge and it has the large reference numbers which should be easy to get it very close to where you want it!
Jake C6R is offline   Reply With Quote
Old 05-25-2011, 05:18 AM   #22
ramjesr's Avatar
To bad for me this wasn't posted a couple of days ago, I just ordered the set-up tool by Hudy. What do you mean each wheel is half the total toe? I thought if you want 2.0 deg. toe in or out you set each wheel 2.0 deg. Who knew? Thats good to know cause I would have been running twice as much toe.
ramjesr is offline   Reply With Quote
Old 05-25-2011, 05:42 AM   #23
I would like to know about this also and tyvm for the picture.
hhbarton11 is offline   Reply With Quote
Old 05-25-2011, 06:29 AM   #24
Jake C6R's Avatar
I thought it was 2.0 total but it appears it should be 2.0 degrees out for each side!
Old 05-25-2011, 06:39 AM   #25
Stubbs's Avatar
Been a year since I originally posted that sketch...nice to see folks are still getting use out of it.
During that time, I've doen a bit more research. On full size cars, total toe is indeed the sum of L & R. However, RC cars seem to be different. I checked the rear wheels on a number of different manufacturers, using the toe plates specified for different toe angles.
On all of the cars that I've measured, the measurement listed on the toe plate (2.0, 2.5, 3.0, etc...) turned out to be the value in degrees AT EACH WHEEL. So, I can only assume that the same logic should be applied to the front end as well.
I've been setting my toe using the camber gauge method for many months. I now use the reading on the camber gauge as the toe on each front wheel (ex. if you want 3.0 degrees of toe, set the camber gauge to 3.0 deg, and adjust each wheel to match).
Thanks....
Old 05-25-2011, 07:25 AM   #26
The Hudy tool is not a necessity but is very useful to me. I always use it for initial setup and love the results.
I find that it is very easy to be off by 1.5 degrees due to tire and wheel imperfections so the station gives you a very accurate starting point.
Sonora is offline   Reply With Quote
Old 05-25-2011, 08:10 AM   #27
Jake C6R's Avatar
Thanks....
Thanks for this info! Well now I'm confused about the proper toe for the 8ight-T 2.0. I thought it was 2 degrees total out but you are saying it's 2 degrees at each wheel for a total of 4 degrees toe out?
Old 05-25-2011, 10:50 AM   #28
Jake C6R's Avatar
After researching a bit further it looks like I was wrong when I said it was total 2.0 - it appears it is 2.0 degrees out for each side!
Old 05-25-2011, 01:10 PM   #29
cool scetch stubbs, similar to how it's done on 1/1 cars. I have the hudy station and i use it after every rebuilt and before each race. Very consistant, very acurate. it's not just camber, caster, toe, it also gets your steering throw 100% acurate.
Is it worth the money? who knows, but i am glad i have it.
"You are not understanding the fundamental principles of my fragmented personality"
Mugen
dreaux is offline   Reply With Quote
Old 05-25-2011, 02:37 PM   #30
ramjesr's Avatar
I've been juked again There is no total toe just a measurement at each wheel.
Hudy set-up Station #108255 xrcbuggy Nitro On-Road 29 04-23-2011 01:27 AM
t2'008, losi xxxcr, 2-pulsar 3 chargers, hudy set up station, xray spring set Jaz406 R/C Items: For Sale/Trade 18 04-01-2010 10:45 AM
Hudy Set Up Station mudboger07 Nitro Off-Road 32 01-28-2010 08:15 AM
Hudy Set up Station hype Australia For Sale/Trade 16 06-30-2007 08:30 PM
Hudy Set-Up Station, CE Pitbull, and Losi Tools for Sale MUDVAYNE R/C Items: For Sale/Trade 18 01-04-2007 07:37 AM
