Old 04-26-2010, 02:09 PM   #1
Default How long should my losi clutch last?
Losi 8ight t 2.0 rtr. Has 2 silver shoes and 2 blue ones. I have almost 2 gallons on these shoes(about a gallon at race tune). They show some wear but still look good and grab good. So when do i know i need new a clutch? And do you get a new clutch bell with new clutch? What clutch is recommended? Thanks!
bacchus is offline   Reply With Quote
Old 04-26-2010, 06:03 PM   #2
ScottyM's Avatar
Trader Rating: 27 (100%+)
2 gallons is about the extent of clutch shoe life.. I've seen some that only last 1 gallon and some that go 3-5gallons.. Depends on driving style and shoe material. You should be able to wear the shoes right down to the springs.. Don't go farther than that though.. Always makes sure to trim the junk off the edges..
Scott Musgrave
ScottyM is offline   Reply With Quote
Old 04-26-2010, 07:47 PM   #3
Frank L's Avatar
Trader Rating: 148 (100%+)
Depends on the spring setup and the engine. I have used combos where the shoes are gone in a 30 min main. I would say 2 gallons is about the limit. But what dothey measure across. 23.3 is the minium.
Old 04-26-2010, 09:05 PM   #4
losi_racer's Avatar
Trader Rating: 25 (100%+)
bearings play a role to. I got an avg of 1.5 gallons thru my shoes in both buggy and truggy, in buggy i use black and green springs and truggy i use gold and green. since going to tko clutch bearings i get avg of 2.5 gallon in buggy and 2 gallons in truggy, and thats measuring until 23.4
Byron Fuels/AKA Tires/Radiopost/TKO/Viper Rc/Dialed Inc/Empire Metal Product/Advantage Racing Products
losi_racer is offline   Reply With Quote
Old 04-26-2010, 09:23 PM   #5
tc5 man's Avatar
losi racer have you tried a all, alum clutch setup with all gold springs on a truggy?
Old 04-26-2010, 09:27 PM   #6
Frank L's Avatar
Ok I guess I could see that. Less drag could make the shoes last longer. I just go with the 23.3 or 23.4mm measurement. I check it every time I pull the clutch apart usually before every main and replace as needed.
Old 04-26-2010, 09:43 PM   #7
losi_racer's Avatar
yea, its a great set up but i like the comp shoes, it saves your clutch bell from the slag. When i ran all alum i was replacing the cb about every other time. try it tho you may like it, i will go to that if i need more bottom end on a small track
im very anal about my clutch. Its hard for me to hear it apart before my main because our turn outs have not been the greatest and i pit my dad so with pitting, racing, and marshalling im busy considering there usually is only 3-4 heats. i tear my clutch apart before my weekend of racing at least, clean the shoes, clean the bell, i learned if you clean the tko bearings they fail fast so i just wipe them off with a rag. I measure the shoes and if i dont think i can get a day of racing with the measurment i see i will replace them before hand
Old 04-26-2010, 09:50 PM   #8
air8's Avatar
The TKO inner bearings are great. I have way better luck with them.
In truggy I'm gonna try 3 aluminum/ 1 carbon. I'd like to find out what it feels like as well as CB wear and tear.
--Driver...you are cleared into the track.....Smoke On.
--"U Ain't Fast!!"
Chris Pearce
air8 is offline   Reply With Quote
Old 04-26-2010, 10:05 PM   #9
Trader Rating: 35 (100%+)
I have had pretty good luck with the two plastic with green springs and two aluminum with gold springs, has anyone tried running 4 plastic shoes?
Hobbs263 is offline   Reply With Quote
Old 04-26-2010, 10:54 PM   #10
tc5 man's Avatar
im running a hd losi eight clutch bell the brown one, do you think that the all alum clutch setup, will eat that clutch bell up?
i tried the green/carbon and gold/alum, and it dint feel like i had enough punch for the truggy.
im gone to be running on a big outdoor track.
Old 04-27-2010, 02:07 AM   #11
DiaRh34's Avatar
Send a message via AIM to DiaRh34
I ran my 2.0b rtr with 4 answer shoes all last season. Probably 3+ gallons. Then i ran them one race this season and thought maybe I should have a look and yeah they were definitely toast after that
says something for answer shoes I guess. I put those back in it.
Taco
Bullet Town raceway Milan, Tn
TLR 8b - Tekin - SMC
DiaRh34 is offline   Reply With Quote
Old 04-27-2010, 05:52 AM   #12
I run dyn Max Life Shoes, I got a season out of them last year. I use Avid dollar bearings, I get a full race day on them.... gold and silver springs.
TLR - Spektrum - Horizon - TLR 8ight 4.0 - TLR 8ight-T 4.0 - TLR 22 4.0 - Orion
token is offline   Reply With Quote
Old 04-27-2010, 06:10 AM   #13
Suspended
Trader Rating: 202 (96%+)
well i was going to start a new thread, but i will ask here since you all are talking about springs. i run 4 aluminum shoes with green and gold springs, can someone please explain what the differnt springs do and what they are good for (short tracks-long tracks- technical tracks......ect) thanks alot, mike
inferno13 is offline   Reply With Quote
Old 04-27-2010, 06:23 AM   #14
air8's Avatar
Softer springs, carbon shoes, soft aluminum will engage earlier. Less wheel spin on dry tracks but it becomes more difficult to jump obstacles right out of a corner.
The stiffer springs, hard aluminum shoes engage later. The engine will rev more before engagement. This is creates wheelspin on loose tracks. It will be easy to clear jumps right out of a corner. This setup is more desirable on high bite surfaces.
There are many more characteristics to answer your questions. I'll let others step in there.
--"U Ain't Fast!!"
Chris Pearce
Old 04-27-2010, 01:06 PM   #15
DiaRh34's Avatar
It tells in the 8ight manual I'm pretty sure about what different shoe/spring combos will do
Taco
Losi 8ight building and setup JBRacing Nitro Off-Road 8691 06-27-2011 08:43 AM
Losi Truggy rcfreak24 Nitro Off-Road 1884 12-27-2009 12:53 PM
Losi clutch probs piranha21 Nitro Off-Road 28 09-04-2009 12:34 PM
Best Engine (speed/torque/fit) for Losi 8ight? tbone555 Electric Off-Road 32 05-14-2007 07:18 PM
