Old 04-26-2010, 12:55 PM   #1
Suspended
Trader Rating: 202 (96%+)
Default losi truggy breaks???
was just wondering if you want more break in front or rear or the same for both in a losi truggy?? anybody have ideas or suggestions? thanks
inferno13 is offline   Reply With Quote
Old 04-26-2010, 12:59 PM   #2
Front will have a little more break. If you put to much break on the rear, you will cause to much stress on the rear diff and you will constantly have to re-shim.
I'm not sponsored so it does not matter what I put here.
Shuming is offline   Reply With Quote
Old 04-26-2010, 01:16 PM   #3
tc5 man's Avatar
is this true with the eight-t 1.0 too?
Old 04-26-2010, 01:24 PM   #4
SteveP's Avatar
Uhmmmmmm, it's "brakes." "Breaks" implies that it's easily broken.
SteveP is offline   Reply With Quote
Old 04-26-2010, 01:24 PM   #5
I heard that it was, but I did not have that gear mesh problem in my 1.0. With the 1.0 they just said use the alu bearing holders in the rear diff
Old 04-26-2010, 01:31 PM   #6
tc5 man's Avatar
oh i have the plastic diff holders, hopelly they will hold up for a race.
yea i never had a problem with the, 1.0 buggy diffs but than again a buggy is lighter.
Old 04-26-2010, 01:43 PM   #7
JAMMINKRAZY's Avatar
Trader Rating: 17 (100%+)
I run almost zero front brake. Running a lot of front brake will make the truck push like a dump truck under braking. I set the fronts so they are just barely dragging and set the rears to hold hard, but not lock up. 1.0 or 2.0, that is how I set my brakes.
Not sure about the whole rear end stress issue. That's a new one for me. If everything is shimmed correctly, brake won't hurt the rear end.
-Koby Kubrin-
Thanks to my Sponsors:
Serpent America | Team Novarossi | Desoto Racing | Race AKA | Ridgeway Bodies
JAMMINKRAZY is offline   Reply With Quote
Old 04-26-2010, 01:44 PM   #8
Slider30250's Avatar
Inferno, the best thing to do is to test your brakes on your local track to see how they do. Set your end point on your brakes to give you a good solid stop without locking up your front or rear tires, then brake into a couple of corners to see if your truck understeers or oversteers. Add rear brake for understeering on corner entry, add front brake for oversteering on corner entry. Finally readjust your end point as necessary.
Anyone can crash, I crash with style
Mugen MBX6R/Airtronics M11X/Ninja Engines/Sidewinder Fuel/EB Mods
Slider30250 is offline   Reply With Quote
Old 04-26-2010, 01:56 PM   #9
How do you control the nose in the air? I run the total opposite, I dont have a problem with it pushing. But a pro did tell me to take out some rear break because it was causing rear diff stress. IDK, thats just what I was told and how I run it, and like it alot.
TLR - Spektrum - Horizon - TLR 8ight 4.0 - TLR 8ight-T 4.0 - TLR 22 4.0 - Orion
token is offline   Reply With Quote
Old 04-26-2010, 02:06 PM   #10
I really just think this is one of those preference things. Some of the tracks I run on are really tight, and running a lot of front brake wouldn't work(at least for me). As for the in air corrections, the nose will come down easily even with little front brake if needed. I don't find that I need to bring the nose down very often anyway. I can see rear brakes causing an issue with the rear end if they are set to lock up completely, or you are jamming on them all the time, but other than that I don't see it.
-Koby Kubrin-
Old 04-26-2010, 02:15 PM   #11
Madbrad's Avatar
Trader Rating: 29 (100%+)
I played around a few months ago with my break set up and found that having more rear break helped me take the corners faster. i was able to hit the break and make the rear slide a little and still having my front with very little break so i could still stear, then hit the gas and be gone out of the turn.
XT8 - Werks B5
Hyper 10SC Novak PRO ESC 4.5HV
Madbrad is offline   Reply With Quote
Old 04-26-2010, 02:19 PM   #12
Suspended
thats kinda what i have been doing, sundays race i would apply alittle brake and it would flip right over, (way to much front...lol) but as soon as i knew not to apply so hard, man, that thing was hooked through the corners in and out. im thinkin if i set front alittle looser it will be perfect, just wondered what other guys had to say! thanks for the reply!! mike
Old 04-26-2010, 02:20 PM   #13
Same here!
-Koby Kubrin-
Old 04-26-2010, 02:21 PM   #14
Suspended
you should'nt need to control in the air if you hit the jump right to begin with, my truggy flys extreamly leval, just wondered about the cornering part of it.
Old 04-26-2010, 02:22 PM   #15
Agreed!
-Koby Kubrin-
Hot Bodies D8 Truggy Greg B Nitro Off-Road 10028 08-16-2017 05:44 PM
Losi 1/8 8ight E 4wd Thread tyhodge07 Electric Off-Road 8898 11-17-2015 05:31 PM
BCE speed Losi 8ight 2.0 3mm chassis xxxtcr Nitro Off-Road 355 12-17-2012 11:05 AM
Losi Truggy rcfreak24 Nitro Off-Road 1884 12-27-2009 12:53 PM
