Clutch Bearings
#31
David with Avid will take care of you for sure and if you have a prob let him know because he will do what he can to fix the prob so it doent happen again if its something with hes bearings
#33
For those interested, hdcruzer contacted me about this and I take such things as #1 priority. What was happening to him is just unacceptable by my standards.
hdcruzer - Will you be running on the same track that you told me about before? I will have that package going out to you shortly. Look forward to hearing back from you.
#34
I have used every bearing compny out there, well not ready cause I just learned about them, but I use Avids for everything including the clutch. I will not pay over a buck for bearings period. Right now, for a club race, i get a day out of them, and if its a big race, i change them before the mains. I have had EVERY bearing out there fail and two or 4 bucks a day, is better that 60 in parts.
#35
The TKO does last longer. Do your periodic checks, clean up and re-oil and it lasts.
#36
#37
I've been using the J&T Ultimate clutch bearings for quite some time now with great success.
#40
I am happy with my 20 cent a piece cheap Asian bearings. No pain at al to replace them every race.
#41
By far? Have you tested them all?
#42
Not all but i believe all was mentioned and some . Tko, avid, stock kit from every major brand , Jim's, fast Eddie's, China
And j&t kill them for me
Tko was a good second
And yes everyone has there own opinion
J&t have had the least issues for me and what iv seen at the tracks I'm at and they put me on the box not sponsor either
#43
Don't waste your money on the No Namer brand bearings.
I have had really good luck with Avid Ceramic bearings n my clutches.
I have had too many flame outs when I try to push and extend the life of clutch bearings. Not worth the worry, I enjoy finishing.
I like to rely on other issues to not finishing, like driving 😉
#44
Ceramic bearings all the way. I use Boca Yellow Seals, but any ceramic bearings should work well. As a bonus, you can degrease the inner bearings and run them dry so they don't eventually fling grease all over the clutch bell, and because the balls are ceramic, they will keep the bearing races polished and smooth even without grease.
That is a ridiculous waste of resources. There is no reason to replace bearings more often than absolutely necessary. You are the last person I would've expected to suggest using disposable parts just because they're inexpensive.
#45
To make it clear, I do not replace them every race but I know people who do that. With a regular lubrication even these cheap bearings can last several races. But if you have expensive bearings you want to extend the life, with 20ct bearings there is no need to think about that.
