Old 04-24-2010, 04:21 PM   #1
newuserlosi8t's Avatar
Trader Rating: 65 (97%+)
Default how hot should a motor run
how hot should a .28 motor be running at just a genral guess
i checked my heat today on a sportwerks .26 and it was running great tuned in and checked my temp its at 269
zo1b team option buggy
mg66 go 2072 a main fuels savox servos
TEAM DRIVER FOR----ANSWERRC-USA--- PREMIEREHOBBIES--answerrcusa.com-http://premierehobbies.com ***Contact me for pricing and information on Argus, Hyperion, Max Amps, Durango and Savox***
newuserlosi8t is offline   Reply With Quote
Old 04-24-2010, 04:33 PM   #2
Bengsch85's Avatar
What engine is it? Different manufacturers and different model engines have different recommended engine temps but as a general anything over 300 is really bad and under 275 is usually a good guess
D8T/Werks B5~~~~OFNA 9.5/Picco P3 B~~~~TTR ST1/Jammin JPL.28
Savox/Spektrum/Odonnell Fuel
Team Terribles www.teamterribles.com
www.clarkrcpark.com
We are always looking for more racers at the track!
Bengsch85 is offline   Reply With Quote
Old 04-24-2010, 04:36 PM   #3
j_blaze14's Avatar
Trader Rating: 34 (100%+)
as hot as you can get and still have smoke at the end of the straight, good puff right after.
aGama A8 EVO - Werks B2 - Sidewinder
aGama A8E - TrackStar 150a, 2560kv, 3 and 4 cell
FlySky GT3B, Turnigy HV servos, SKY Lipos
AKA, Proline, Hotbodies Rubber
Elite Performance - HORRC.com
j_blaze14 is offline   Reply With Quote
Old 04-24-2010, 04:42 PM   #4
Bengsch85's Avatar
Oh sure if there is smoke you still got the lube you need in the engine but over 300 you start hurting the integrity of the engine parts and you'll cook your engine anyways.
www.clarkrcpark.com
Old 04-24-2010, 04:54 PM   #5
bobbitrc's Avatar
If the engine block is glowing......... It's too hot
Bengsch85 is right, but every engine is a little different. I've got a TRX 2.5 that always runs close to 300 and loves it. Till it goes BANG!!
You might run a Two-stroke.....But I run a Rotary!!
Where did you learn to whisper?...A sawmill???
bobbitrc is offline   Reply With Quote
Old 04-24-2010, 05:02 PM   #6
Jaz240's Avatar
Trader Rating: 52 (100%+)
Everyones answer is right. All engines are different but try not to exceed 275. Tune for smoke trail and performance not temps but always check to make sure it's not too hot. There is a very narrow gap between a perfect tune and too hot or to cold. Cold will hurt your engine just as fast as heat will so make sure you are in that golden range of 200-250 after a good 1/2 tank of running in normal conditions. I know RB engines like to run a little hotter than others and the trinity ex techs run a little colder. Of course if I could tune as well as I can type my life would be allot simpler
nothing to see here................................
Jaz240 is offline   Reply With Quote
Old 04-24-2010, 05:14 PM   #7
Default motor
i have a sh .28 runs at 250 good smoke
sportwerks .26 269 to 279 but the head had smoke coming off it maybe it was some oil on the head that burned off
Old 04-24-2010, 05:16 PM   #8
i always tune my motors by ear and performance then check temps
Old 04-24-2010, 07:14 PM   #9
mudslinger's Avatar
Don't get caught up with temps. I always tell people the best thing that ever happened to me was my temp gauge quit working. Tune for performance and smoke, then verify that your temps are ok. You can have smoke and performance and be too hot so if that happens just richen it up a little, or make sure that you have good airflow to the head.
http://events.rcsignup.com/events/displayEvent.cfm?ID=2777
mudslinger is offline   Reply With Quote
Old 04-24-2010, 08:06 PM   #10
look right above ur post it says i always tune by ear and performance then check temps
Old 04-24-2010, 08:19 PM   #11
Depends on alot of things for one what is it in monster truck vs buggy. The tune pipe has alot to do with temp airflow over the engine.
I had picco 26 in savage that ran 300 all the time. Put that same engine in truggy it was very rich had to lean everything alot and temp was 250. Then let my brother use it in a buggy had to lean it some more same temp.
pdmustgt is offline   Reply With Quote
Old 04-25-2010, 08:20 AM   #12
i was just curious ... how many gallons of fuel do you burn before this BANG happens .
what are most life spans for a nitro motor.
my first monster truck used a bunch of glow plugs and seized at four gallons.
now my savage x ss is on it's third glow plug and at least ten gallons of 20 %.
i run it 200 - 220 but the specs say up to 275 is ok
rc everywhere is offline   Reply With Quote
Old 04-25-2010, 08:48 AM   #13
Maximo's Avatar
Heat really doesn't hurt these engines...lack of lubrication does..... you can run 300 if the engine is well lubricated, not that it really happens that way.....but worry more about having a good tune and forget about your silly temp guns !
Maximo is offline   Reply With Quote
Old 04-25-2010, 08:51 AM   #14
Trevor Williams's Avatar
Trader Rating: 195 (100%+)
+1
RC10-B6d | RC10-B64d
SmacTrac
#WeAreAE #ReedyPower #AE4Life
Trevor Williams is offline   Reply With Quote
Old 04-25-2010, 08:56 AM   #15
i have it in a losi 8 buggy
how hot should a brushless motor get? AmmoJammo Electric Off-Road 18 01-16-2010 06:52 AM
how hot is too hot peterel Rookie Zone 6 06-08-2008 09:00 PM
How Hot Is Too Hot? Nrctc3 Electric On-Road 18 09-18-2004 03:11 AM
How Hot Is Too Hot????? Steevo Electric On-Road 51 12-04-2002 09:56 PM
