Old 04-24-2010, 01:50 PM   #1
Default Cant get fuel to feed into carburetor
I cant get the fuel to feed into the carburetor when bump starting. I put my finger over the pipe and it still wont feed.
Is the problem in the tank or lines or could it be in the engine as well.
wrayth is offline   Reply With Quote
Old 04-24-2010, 01:52 PM   #2
Ovaloldtimer's Avatar
Take the line loose from the pipe and blow thru it til fuel reaches the carb
Ovaloldtimer is offline   Reply With Quote
Old 04-24-2010, 01:54 PM   #3
There has to be something else wrong to have to do that all the time.
Old 04-24-2010, 01:57 PM   #4
gkn0315's Avatar
Trader Rating: 126 (100%+)
did it start that way
Glenn Nail
STRC LCG Slash looking for electronics
1985 Associated RC 10 Novak t4 Trinity Monster Horsepower 27T futaba Jr
gkn0315 is offline   Reply With Quote
Old 04-24-2010, 01:59 PM   #5
If I can get the fuel to the engine it starts fine.
Old 04-24-2010, 02:01 PM   #6
replace the lines, replace the gaskets, make sure the head is on tight, make sure the carb is sealed and no air is getting in.
C.Harper is offline   Reply With Quote
Old 04-24-2010, 02:03 PM   #7
That was my next step. I am going to check for air leaks on everything.
Old 04-24-2010, 02:04 PM   #8
Suspended
Trader Rating: 41 (100%+)
Most common is fuel cap seal, next is fuel lines. You may have a plugged tank stone, but you'd have lean issues as well...
I always pull off the pipe hose and blow through to prime anyway. Excessive spinning over cold will wear the engine a little faster.
Puppies! Flowers <3
Cadimman is offline   Reply With Quote
Old 04-24-2010, 02:31 PM   #9
Jason Pelletier's Avatar
Trader Rating: 33 (100%+)
My friends klunk got jammed up in the tank and kinked the line. took us like 2 min to notice it. ahahah
Island Raceway & Hobby
Jason Pelletier is offline   Reply With Quote
Old 04-24-2010, 02:51 PM   #10
Jaz240's Avatar
Trader Rating: 52 (100%+)
I had the same problem when I got my new V spec. No matter what I did or checked it would not prime. I sent it out and after the case was flux tested it turned out that it was cracked! Yup right out of the box. Cracked case. I had to buy a new case. I hope your problem is not as severe. I would think the first thing you should check is your front bearing. That's usually where severe air leaks come from
nothing to see here................................
Jaz240 is offline   Reply With Quote
Old 04-24-2010, 08:14 PM   #11
front bearing it was.
Old 04-24-2010, 08:32 PM   #12
which engine you running ?
Old 04-25-2010, 02:57 AM   #13
rc skyline's Avatar
A little while ago a friend had the same problem with a brand new rtr.. Turned out the nipple on the tuned pipe where the pressure hose conects was blocked... Worth a look
Dave
MUGEN MBX7R & MBX6TR
FUSION X ENGINES By Novarossi
BUKU Power Clutch
MECCAMO FUEL - BETA Tires
www.fusionxengines.com.au
rc skyline is offline   Reply With Quote
Old 04-25-2010, 04:41 AM   #14
Ws7 II world I got the front bearing out and there is a small tit by the carb inlet on the flat section where the bearing seats. I imagine that this could be causing the problem. (factory defect) can I dremel this off?
Old 04-25-2010, 06:32 AM   #15
rc skyline's Avatar
OK.. im confused
I cant see anything odd in that pic .. Or am i going blind?
BUKU Power Clutch
