Old 04-25-2010, 07:24 AM   #16
Suspended
Trader Rating: 41 (100%+)
Originally Posted by wrayth View Post
Ws7 II world I got the front bearing out and there is a small tit by the carb inlet on the flat section where the bearing seats. I imagine that this could be causing the problem. (factory defect) can I dremel this off?
Only problem I see that casuing is bearing nt seating deep enough. How would that cause an air leak? Did you confirm a leak there before You pulled the bearing?
Puppies! Flowers <3
Cadimman is offline   Reply With Quote
Old 04-25-2010, 10:55 AM   #17
I dd. I just put a new bearing in and its blowing bubbles between the shaft and the bearing.
The contact between bearing and case looks good.
wrayth is offline   Reply With Quote
Old 04-28-2010, 02:05 AM   #18
rc skyline's Avatar
Have you sorted this out yet Wrayth
MUGEN MBX7R & MBX6TR
FUSION X ENGINES By Novarossi
BUKU Power Clutch
MECCAMO FUEL - BETA Tires
www.fusionxengines.com.au
rc skyline is offline   Reply With Quote
Old 04-28-2010, 03:51 AM   #19
Thought I did but i;m having a problem again getting fuel in the carb. Ive replaced the front bearing twice. No air leaks.
Old 04-28-2010, 07:49 AM   #20
Jaz240's Avatar
Trader Rating: 52 (100%+)
If you have tried everything else and it still not priming you either have a problem with your carb somewhere, or your case is cracked.
nothing to see here................................
Jaz240 is offline   Reply With Quote
Old 04-28-2010, 08:40 AM   #21
losiracer78's Avatar
i agree with James. Take you lsn hand blow into the carb and see if you have sucked something up from your fuel or there is crack some where.
Screen Names Has Changed To mayhem04
losiracer78 is offline   Reply With Quote
Old 04-28-2010, 10:13 AM   #22
Replace fuel lines and tank, clean out the pipe nipple, make sure the engine is tight.....
I'm not sponsored so it does not matter what I put here.
Shuming is offline   Reply With Quote
