Old 04-23-2010, 07:07 PM   #1
newuserlosi8t's Avatar
Trader Rating: 65 (97%+)
Default motor problems help
i just got my 8 back from the hobby shop after they worked and tuned my motor the guy at the shop drove the car and it started right up and drove great idle great everything throttle linkadge is set to
i get it home and i can start it rev it up get it to temp then it idles fine drives for a minute then i get on brakes and it shuts off but when the hobby shop guy drove it it didnt die when he got on the brakes it seems like my motor only runs good for other people and just doesnt like me
what should i try
zo1b team option buggy
mg66 go 2072 a main fuels savox servos
TEAM DRIVER FOR----ANSWERRC-USA--- PREMIEREHOBBIES--answerrcusa.com-http://premierehobbies.com ***Contact me for pricing and information on Argus, Hyperion, Max Amps, Durango and Savox***
newuserlosi8t is offline   Reply With Quote
Old 04-23-2010, 07:15 PM   #2
Trader Rating: 61 (100%+)
what should i try
check the throttle linkage ...it may be not set right ...when its at neutral ...try applying the breaks and watch the carb barrel ..see if when you hit brakes it moves in a little more ..just a guess good luck
LATER COOKIE
TEAM REDS RACING ENGINES USA
TEAM PROLINE-RACING
TEAM RC AMERICA/XRAY/HUDY
zixxer is offline   Reply With Quote
Old 04-23-2010, 07:33 PM   #3
tc5 man's Avatar
+1 also if your only using one, throttle coller a rubber band or a thottle return spring will help it from closing to much.
Old 04-23-2010, 08:00 PM   #4
RUNNINONMT's Avatar
I had the same problem once it would start up run fine for a couple minutes
and when i hit the brakes it would die. found it to be the clutch bell bearings.
after they warmed up they would just grab.
RUNNINONMT is offline   Reply With Quote
Old 04-23-2010, 08:53 PM   #5
Suspended
Trader Rating: 5 (88%+)
+2
Check the clutchbell bearings.
carlam is offline   Reply With Quote
Old 04-24-2010, 09:21 AM   #6
Default motor
new shoes new bearings new assebly basicly when i apply breakthe carb slide does not close any more than idle position
Old 04-24-2010, 09:25 AM   #7
what do u mean by throttle collar
E-maxx 3906 with EVX-2 16.8 motor problems tightdog1 Monster Trucks 17 05-26-2009 05:06 AM
New Motor Toasted! Help! Pics inside... z28mccrory Nitro Off-Road 34 01-17-2008 05:08 PM
Glitching Problems...Help Quick! DOMOisCOOL Electric On-Road 39 08-25-2004 05:19 PM
LRP Runner Problems, HELP! LosiFromHell986 Electric Off-Road 9 11-12-2003 05:03 PM
