Old 04-23-2010, 06:13 PM   #1
8IGHTROCKETX3's Avatar
Trader Rating: 59 (100%+)
Default RC8T shock question
my buddy is running an RC8T and keeps blowing the shock cap off the shocks. his are the plastic non-threaded version. has anyone else had this as an issue?
if so, is the fix just to go with the factory team shocks and or the aluminum versions.
any help is appreciated. thanks
8IGHTROCKETX3 is offline   Reply With Quote
Old 04-23-2010, 06:21 PM   #2
JoeyTheRocket's Avatar
Send a message via AIM to JoeyTheRocket Send a message via Yahoo to JoeyTheRocket
The RTR caps are plastic, its to keep the cost of the kit down. The race versions are aluminum.
Also look in here for RC8T questions and answers
Team Associated 1/8 scale Truggy Info and Tips
Joey Kubat ↔ MWNS Staff www.MidwestNitro.com
Mugen Seiki / AKA Racing / Novarossi / PT RC Racing Oils / Advantage Racing Products
JoeyTheRocket is offline   Reply With Quote
Old 04-23-2010, 06:27 PM   #3
pyromania's Avatar
Trader Rating: 18 (100%+)
Most likely he's overfilling the shocks. If you add too much oil, the shock only will compress to a certain point. Once it gets to that point and more pressure is applied to the shocks the caps will give up.
Jesse Carrillo
Team Driver For:
TLR | Horizon Hobby | Nitrotane | Spektrum | HandleITHobbies | 818 Designs
pyromania is offline   Reply With Quote
Old 04-24-2010, 02:13 AM   #4
I never blew the tops of the shocks that came with my RC8T RS; however, I have seen several friends blow the tops of the ones that come with the SC8. I think as they heat up, and the limited threading area on them, they tend to let go on hard hits. Try running, no or very limited rebound, this might help. The instruction manuals tell you how to set the rebound. Also be sure when assembling, that you wait to get ALL the air out before sealing the caps.
If you intend to race, then it really is worth the money to upgrade these to the FT ones.
Tekno NB48 Samurai Proline Tires
Tekno NT48 XZB Speed Proline Tires
Tekno EB48.3 Viper Proline Tires
Tekno / Dialed RC Hobbies / TKO Competition Development /
Stirex is offline   Reply With Quote
Old 04-24-2010, 03:48 AM   #5
aussies1129's Avatar
Trader Rating: 74 (100%+)
common problem just go the aluminium factory teams shocks and try not to overfill and try and adjust droop aswell to prevent over extending the shock
cheers
Proudly supported by......
Premier Model Supplies Pty Ltd
H.E.I AUSTRALIA
XRAY*****PRO-LINE*****HUDY*****
-----FUTABA-----NOVAROSSI-----
aussies1129 is offline   Reply With Quote
Team Associated 1/8 scale Truggy Info and Tips Kevin Boyle Nitro Off-Road 4504 01-05-2017 06:52 PM
