Old 04-23-2010, 04:01 PM   #1
Default Anyone tried this throttle linkage
Dynamite RC Pro Tune Throttle/Brake Linkage Set
http://www.amainhobbies.com/product_...ke-Linkage-Set
I need to buy a new linkage set for my rc8, and I hate the one that comes in the rc8. It's just a pain to adjust and I am constantly having to adjust it after every other run.
What do you guys think of this one?
bevofrancis is offline   Reply With Quote
Old 04-23-2010, 04:10 PM   #2
jmaxey51's Avatar
i use nothing but that linkage. best bang for your buck. the only problem is you have to bend the brake bars just a little so it clears the center diff top plate.
jmaxey51 is offline   Reply With Quote
Old 04-23-2010, 04:41 PM   #3
Agreed using it on my truggy, I had some brake issues because the lower ball cap was to tight wouldn't let the bar move freely, stuck it in a drill and spun it a couple times,,,magic...then i bent the bars so it would fit over the diff..
But I like it
jbusch1983 is offline   Reply With Quote
Old 04-23-2010, 04:54 PM   #4
KWT-NITRO's Avatar
best linkage ever, i run on all my cars.
i put a 2mm washer between the 2 brake bars plastic ends ( where they sit on the servo horn to make things freeier.
cheers
ALi
Team Kuwait, Team Terribles, www.rccck.org
Kuwait National Champion
FEMCA Truggy Finalist & FEMCA Buggy Semi-Finalist
Thanks to all my sponsors: Modelix/Ultimate Racing, AKA Racing, AVID Racing, Stick-it1 Racing and HES
KWT-NITRO is offline   Reply With Quote
Old 04-23-2010, 05:07 PM   #5
tc5 man's Avatar
isnt that the same linkage as the losi eight linkage?
nevermind it isnt i might try this linkage out.
Old 04-23-2010, 05:09 PM   #6
KWT-NITRO's Avatar
Nope
Old 04-23-2010, 05:13 PM   #7
tc5 man's Avatar
Originally Posted by KWT-NITRO View Post
Nope
if you use it on the eight, where do you use the other 2 balls cups at?
and whats the rod, sticking out of the ball cup? does it get rid of the slop thats in the eight linkage?
Old 04-23-2010, 05:44 PM   #8
I got to looking at my rc8, and it has the brakes and throttle side by side. This linkage setup is over and under each other.
Would I still be able to use this?
Old 04-23-2010, 05:48 PM   #9
Trader Rating: 21 (100%+)
the ball cup end that has the red adjusting knob goes to your carb. The two rods go into your fr and rr breaks. You will have to take out your old rods and place these in through the holes.
TopGearRC is offline   Reply With Quote
Old 04-23-2010, 05:49 PM   #10
jmaxey51's Avatar
yes but it will take some changes. you have to mount them on the top of the horn and you will need a longer screw with a lock nut on it. like from the bottom up threw the top with the nut on top. its hard to explain but can be done.
Old 04-23-2010, 05:50 PM   #11
Eagle7's Avatar
Trader Rating: 25 (100%+)
Nope
MBX7T-Werks B5-2013. MBX7T Eco
MBX7r-Werks B6-2058 MBX7r Eco
TLR 22 2.0 & 22 2.0T
Werks Racing
Eagle7 is offline   Reply With Quote
Old 04-23-2010, 05:52 PM   #12
Armaan's Avatar
Trader Rating: 49 (100%+)
Nice, just ordered one up. Thanks for the post!
Armaan is offline   Reply With Quote
Old 04-23-2010, 05:58 PM   #13
wetfoot's Avatar
I use this setup to on my RC8. Below is a link with a pic or 2.
http://www.rcuniverse.com/forum/m_80...tm.htm#8089522
wetfoot is offline   Reply With Quote
Old 04-23-2010, 08:14 PM   #14
Dlewis4's Avatar
Trader Rating: 148 (100%+)
i use that linkage, the dynamite. very easy to setup and use
Why is this hobby so full of drama? Its toy cars....
Dlewis4 is offline   Reply With Quote
Old 04-23-2010, 10:40 PM   #15
merdith6's Avatar
Default the rc-8 linkage
The stock one is great. No issues at all, actually it's one of the better ones...
Mad Dog drives a Mugen MBX-7, Novarossi engines, Clockwork Racing, Futaba radio, AKA/Proline Tires
merdith6 is offline   Reply With Quote
Serpent 720 rcrossco_1 Nitro On-Road 5073 04-16-2012 08:42 PM
Losi Truggy rcfreak24 Nitro Off-Road 1884 12-27-2009 12:53 PM
picco .26 break in problems please help! atebit Rookie Zone 33 08-12-2007 05:54 AM
