Old 04-22-2010, 11:10 AM   #1
Default Neutral Brake and abs brake
how does neutral brake work and, does it come on for so long after the throttle is returned to neutral and then stop or is it just like a drag brake, i notice the futaba 4pk has this feature, any help would be appreciated. Russ
speedzone99 is offline   Reply With Quote
Old 04-23-2010, 06:35 AM   #2
Old 04-23-2010, 07:10 AM   #3
KWT-NITRO's Avatar
man i dont understand your question not sure what you really need to know here??
cheers
Ali
Team Kuwait, Team Terribles, www.rccck.org
Kuwait National Champion
FEMCA Truggy Finalist & FEMCA Buggy Semi-Finalist
Thanks to all my sponsors: Modelix/Ultimate Racing, AKA Racing, AVID Racing, Stick-it1 Racing and HES
KWT-NITRO is offline   Reply With Quote
Old 04-28-2010, 10:18 PM   #4
Goomba_7's Avatar
I believe that neutral Brake is similar if not the same as Drag brake. with this setting you can adjust the amount of the brake that is applied when the throttle is in the neutral position. I know a lot of electric guys use this setting in touring cars a lot. I'm not sure if this is a common practice in off road. As for ABS, you can set the radio can send a pulse signal to the RX which is effectively like True ABS but there is no sensors on your car, it just applies every time you hit the brakes. This can however be bad for your servos. it probably works better in electric cars. Try a search in the radio forum you might have better luck there.
Serpent Cobra S811, Which ever engine is running good for me, VP Fuel, Savox Servos
"A bad race day is still better than a Good work day!"
Goomba_7 is offline   Reply With Quote
Newbies Queries - Ask and you shall be answered! renben Singapore R/C Racers 4617 07-21-2017 11:28 PM
Futaba 3PK Radio/Receivers/Case and much more Toiffel R/C Items: For Sale/Trade 7 02-12-2010 04:11 AM
Do you use ABS??? V1-RRR-WC Nitro On-Road 22 10-30-2006 07:59 PM
Is ABS radio feature helpful with front one way IDrinkNitro Nitro On-Road 14 02-25-2004 09:31 AM
