Old 04-22-2010, 08:12 AM   #1
Default Quick Tire Question
Is it true that by boiling my rims the tires will come off easier? I was just told this by my neighbor but want to ask before i destroy them. Thanks
ADT1976 is offline   Reply With Quote
Old 04-22-2010, 09:09 AM   #2
DOMIT's Avatar
Location: Fort Worth, Texas, USA, North America, Earth, Solar System, Milky Way Galaxy, Universe
Send a message via MSN to DOMIT Send a message via Yahoo to DOMIT
Yes... or baking them in the oven... or putting them in a sealed container with acetone (they don't have to be in the liquid, just the fumes will do the trick if you leave them in there long enough.)
Brad "DOMIT" Smith - I'm not fast, but at least I wreck a lot.
Unsponsored, but I use/recommend: XRay XB9, Alpha A852, Dynamite 053, Airtronics M11, Hitec 5955TG & 7955TG, ABEC 35 clutch and chassis bearings, PTRCRacing shock and diff fluids, Ready Rollers ceramic engine bearings. ** Team Terribles Region 9 coordinator. ** JOIN TEAM TERRIBLES! All racers welcome! PM me for details.
DOMIT is offline   Reply With Quote
Old 04-22-2010, 10:35 AM   #3
b4maz's Avatar
Trader Rating: 8 (90%+)
+1
Tons of speed run videos and information:
www.fastestrc.blogspot.com/
b4maz is offline   Reply With Quote
Old 04-22-2010, 10:41 AM   #4
freestylinmotox's Avatar
+2
when in doubt, throttle out! braaap!
freestylinmotox is offline   Reply With Quote
Old 04-22-2010, 11:03 AM   #5
dash riprock's Avatar
I just tried the acetone method the other day.The tires fell off when I was taking them out of the can.That method works awesome!
Tony Hopcraft
Losi 8ight-T 2.0 Losi 8ight 2.0 Losi Mini-Late Model,Losi L8ight Model
Hobby Revolution Team Driver
dash riprock is offline   Reply With Quote
Old 04-22-2010, 04:55 PM   #6
tristyn's Avatar
Default TIRE REMOVAL
My experience with boiling tires sucked and it stinks up the house. Use acetone
tristyn is offline   Reply With Quote
Old 04-22-2010, 05:17 PM   #7
2fst2c's Avatar
Trader Rating: 114 (100%+)
I've boiled them and worked great. About 15 minutes per tire. I used a pair of Ov Gloves and pulled them right off. Didn't notice a smell. Baking will smell up the house. Haven't tried the Acetone, but I've heard it can ruin the foams. ?
2fst2c is offline   Reply With Quote
Old 04-22-2010, 05:18 PM   #8
Use the acetone outside too,its not a pretty smell either.LOL
Tony Hopcraft
Old 04-22-2010, 06:03 PM   #9
K_B
K_B's Avatar
Trader Rating: 69 (100%+)
As I understand it, you don't actually have to submerge the tires in acetone. If you suspend them above some acetone in a sealed jar, the fumes alone will do the trick and you won't wreck the foams. I use the baking trick and it works, both for removing tires and stinking up the house.
K_B is offline   Reply With Quote
Old 04-23-2010, 08:53 AM   #10
Reno's Avatar
Trader Rating: 16 (100%+)
acetone works great! before putting them in the container, cut the tires off the rim. leaving only the bead. remove the foam and then place in the container over night. the bead will fall off!
Reno is offline   Reply With Quote
Old 04-23-2010, 09:05 AM   #11
b4maz's Avatar
Did you have any trouble with glue residue on the bead of the rim? Did it clean right off?
Old 04-23-2010, 09:53 AM   #12
Davidka's Avatar
Trader Rating: 75 (100%+)
The glue more or less dissentegrates with the acetone method. Word of caution: If you are removing losi pink, panther c, j concepts gold, or proline mc and you mean to re-use the tires, [U]do not[U] use acetone. It will shrink and harden the rubber on those compounds. Your foam will likely be unusable too but I suspect if the tires and foam were good you wouldn't be removing them, eh?
Panther 1/8 SC tire question gigana23 Electric Off-Road 11 04-02-2010 07:02 PM
Quick diff question new to rc cars Nitro Off-Road 31 07-16-2008 03:41 PM
quick differential question cyclone Electric On-Road 7 12-04-2005 08:58 AM
