Old 04-21-2010, 06:35 AM   #1
Chris Griffiths's Avatar
Default Losi shocks problem
Hi guys ive just got a new Losi EU, The front shock pistong comes out of the shock body when fully compressed is this correct?
Also does everyone run the little foam inserts above the bladders?
Thanks in advance
Chris
Tamiya TRF 801x
Tecnopower
Futaba 4PK
Chris Griffiths is offline   Reply With Quote
Old 04-21-2010, 06:39 AM   #2
BAUSTIN's Avatar
Thanks in advance
Chris
No its not normal.......make shure they are not on the shaft upside down....they should set down on the shaft a little.....also make shure the shock end is all the way tight/snug......on the foams inserts....i run them.....they make the shock rebound more consistent over the race day.......
Billy Austin
www.Code3RC.com
Elevation Sports
BAUSTIN is offline   Reply With Quote
Old 04-21-2010, 06:43 AM   #3
l3asher's Avatar
It is normal, you will be fine. Under race conditions it will never compress that far.
l3asher is offline   Reply With Quote
Old 04-21-2010, 06:46 AM   #4
Everything is normal, piston is on right way etc. and its defo the right shaft as the rears are perfect. Ive screwed shock bottom on all the way till you can only see one thread, basically enough to fit a small pair of snips.
Tamiya TRF 801x
Tecnopower
Futaba 4PK
Old 04-21-2010, 07:33 AM   #5
neobart's Avatar
It's perfectly normal, and as l3asher says the shocks never compress that far. The chassis bottoms out at around 3/4 stroke.
You need to run the foam inserts with the vented EU shock caps. You can run without them, but would need to get some 2.0 non-vented caps.
Clockwork Racing Engines
neobart is offline   Reply With Quote
Old 04-21-2010, 07:35 AM   #6
Ok cheers! Thanks alot.
Chris
Tamiya TRF 801x
Tecnopower
Futaba 4PK
Old 04-21-2010, 09:46 AM   #7
BAUSTIN's Avatar
they are right i misunderstood sorry..........
Billy Austin
www.Code3RC.com
Elevation Sports
Team Losi JRXS Kenshin Electric On-Road 13263 06-13-2016 03:39 PM
Losi XXX-S TSR6 Electric On-Road 14329 01-26-2015 07:59 PM
Rebuilding Losi Shocks? Chris__RC Electric Off-Road 55 08-08-2008 02:54 PM
Losi shocks on AE car CGR Electric On-Road 9 08-28-2003 10:10 PM
