Old 04-21-2010, 03:40 AM   #1
Trader Rating: 26 (96%+)
Default Losi 2.0 T diff wt fluid recommendations
Im currently running RTR which I believe is grease filled.Id like to go to oil filled on all 3 diffs.
Whats a good combo running on a tight track where I can have more pull through the front wheels.
Currently rear wheels are breaking out .
RustyOne is offline   Reply With Quote
Old 04-21-2010, 03:50 AM   #2
TIX
TIX's Avatar
Trader Rating: 17 (100%+)
I run 7K front 10K center and 2K rear
if you use that and the car is a little taily use 3K in the rear instead
alot of people run 3K in the read but im finding that the car rotates into the corner betwer with 2K in the rear
Alan Nankervis.
TIX Race Designs. Plaig Bearings. Thunder Innovations
TIX is offline   Reply With Quote
Old 04-21-2010, 03:51 AM   #3
imaxx21's Avatar
Send a message via AIM to imaxx21
7,10,2 is a good starting point
-Crash
Upgrade RC www.upgrade-rc.com
imaxx21 is offline   Reply With Quote
Old 04-21-2010, 05:41 AM   #4
http://www.horizonhobby.com/ProdInfo...ake8ightT2.pdf
I'm not sponsored so it does not matter what I put here.
Shuming is offline   Reply With Quote
Old 04-21-2010, 05:43 PM   #5
Thanks for the info guys.
Old 04-21-2010, 09:08 PM   #6
Cannondale1974's Avatar
Trader Rating: 29 (100%+)
Wouldn't it be better to go lighter in the center diff if the truck was tail happy, diverting more power to the front wheels? I've read by going heavier in the rear you decrease traction while cornering.
Cannondale1974 is offline   Reply With Quote
Old 04-21-2010, 09:18 PM   #7
I have the same 2.0 8T RTR and here's what I did as the truck can get very loose in the rear with that 454 engine. (it's an animal, tons of power). Soften the clutch and use 2 composite shoes and 2 aluminum shoes. Steel flywheel helps also. Make your rear camber link as long as you can, this helps a TON. Also, I dialed in about 15% exponential on throttle, this helped smooth out the throttle response as well.
Finally, I'm pretty sure it comes with fluid in the diffs, not grease.
