Old 04-20-2010, 08:08 PM   #1
Teccmoney's Avatar
Default hudy break in bench question....
will a mtx4 on road header work with this break in bench with a .21 size engine? if not can some one give me a link to the right header i need..... thanks....
Mugen Mbx6t,speed wc II 2060/ Mugen Mbx6, speed powered/ Losi 5ive-T/
SNR Graphite/M2C,BCE,Fioroni,king headz, byrons gen/ M11 spek pro/ Savox HV
*2011 Kyosho Fall Classic Novice Buggy Champ* 2011 CVR Nitro Nights Truggy Champ*
2012 DRC Winter Series Inter. Truggy Champ*
Daryl Wright aka "thefastblackman"
Teccmoney is offline   Reply With Quote
Old 04-21-2010, 03:43 AM   #2
blade954's Avatar
Trader Rating: 23 (100%+)
I purchased a Losi LST 2 header and pipe for the Hudy run in bench. Works at treat.
blade954 is offline   Reply With Quote
Old 04-22-2010, 07:45 AM   #3
I would think any onroad header will work ... I'm using a Werks ... a few things to note on the Hudy Breakin stand:
*I switched the throttle linkage to the other side so that I didnt have to keep rotating carbs
*They suggest not running an air filter ... you will get blow back from the prop and it will blow fuel all over the engine ... the Revo 3.3 filter assembly will fit and clear the prop
*the wind caused by the prop will drive temps on the engine down ... I would recommend a Competition Heat Engine Warmer and at very least build a shroud with aluminum ... pm me if you wanna see a pic
Jed the Geezer is offline   Reply With Quote
Kyosho Evolva M3 tomkelley Nitro On-Road 1002 05-19-2015 07:49 AM
Serpent 705 J_Longbrake Nitro On-Road 4252 02-22-2015 11:34 PM
