Old 04-20-2010, 05:44 PM   #1
rc_in_mexico's Avatar
Send a message via MSN to rc_in_mexico Send a message via Yahoo to rc_in_mexico
Arrow substitute for after run oil
What can i use intead of after run oil? i heard WD-40 works
rc_in_mexico is offline   Reply With Quote
Old 04-20-2010, 05:52 PM   #2
Peter Martin's Avatar
Mineral oil from a pharmacy. WD-40 is mostly kerosene...not good if your crank is filled.
Peter Martin is offline   Reply With Quote
Old 04-20-2010, 06:11 PM   #3
FLHX1550's Avatar
Marvel Mystery Oil is a good one
FLHX1550 is offline   Reply With Quote
Old 04-20-2010, 06:15 PM   #4
jammin32j's Avatar
I have heard of people using marvel mystery oil mixed with transmission fluid mixed 50 50.
VP Pro, Agama
Hitec-7955's, 3Pk----AKA Racing Tires
Absolutehobbyz.com____Dirtrc.com
O'Donnell, D.I.R.T. R/C ultimate Tire Gluer
Jeremy Davis
jammin32j is offline   Reply With Quote
Old 04-20-2010, 06:15 PM   #5
RUNNINONMT's Avatar
syntheic atf works
RUNNINONMT is offline   Reply With Quote
Old 04-20-2010, 06:45 PM   #6
marvel mystery & air tool oil mixed 50/50 works good.
axle is offline   Reply With Quote
Old 04-20-2010, 08:33 PM   #7
Jaz240's Avatar
Trader Rating: 52 (100%+)
A well respected engine modder told me he uses only Singer light sewing machine oil, and only when his engines are going into long term storage or not to be used for awhile. I took his advice and have not been happier. I dont use ARO anymore unless I know my engine will not be used for at least 2-3 weeks. When I do the singer oil works great. Its really thin and does not hurt anything. It was $4 for a bottle that will probably last me my whole life
nothing to see here................................
Jaz240 is offline   Reply With Quote
Old 04-20-2010, 08:40 PM   #8
teamlosi906's Avatar
Trader Rating: 235 (100%+)
Default oil
i like engine fogging oil works great in any engine, and doest affect silicone ,and the motor starts right up and a spray can last forever best i ever tried out of every after run oil
Serpent S11T Losi ten scte Houston Tuned Team Toronero 2084 ss, plus 4 team 9901 ss pipe Hitech servos Proline tires SPONSORS T@T MOTOR SPORTS AND SKIDOO racing TEAM TERRIBLES,And finally my wallet.In Memory of my Boy Brian!
teamlosi906 is offline   Reply With Quote
Old 04-20-2010, 11:31 PM   #9
Roelof's Avatar
Send a message via ICQ to Roelof
I was told the red afterrun from Tornado is the same as wapon oil.
Speed is only fiction but a 130+km/h MRS4 is for real.
Roelof is offline   Reply With Quote
Old 04-20-2010, 11:45 PM   #10
off road god's Avatar
Marvel mystery....but I tear mine down after every raceday and clean it real good with simple green and dawn....then spray it down with denatured alchol and blow all the moisture out with a air gun. Nitro methane is famous for attracting moisture and causing rust on your crank and bearings. When I put it back together I use Benol(castor oil) to lube everything. Then,if you want to store the motor,just plug it up and don't worry about it...you have all the dirt and moisture causing elements taken care of....
off road god is offline   Reply With Quote
Old 04-21-2010, 12:14 AM   #11
Considering the
jonusb is offline   Reply With Quote
Old 04-21-2010, 02:53 AM   #12
awdcameolsx's Avatar
Trader Rating: 36 (100%+)
Depends on your motor. I have seen marvel mistery oil and WD40 destroy filled cranks. Sewing maching oil in a really light coat is really the only thing I would substitute.
awdcameolsx is offline   Reply With Quote
Old 04-21-2010, 10:15 AM   #13
With todays fuel you really don't need after run oil.
pdmustgt is offline   Reply With Quote
Old 04-21-2010, 10:20 AM   #14
Joel Lagace's Avatar
WD40 and or Marvel mystery oil..
The good thing with WD40 is its good people who run there motors alot. For short term storage like less then a week. IT keeps things lube and allows for quicker start ups when u got to run the engine again. MArvel is better suited for longer term storage.
"Without Rules its just Backyard Bashing!"
www.rcottawa.com
Joel Lagace is offline   Reply With Quote
Old 04-21-2010, 10:23 AM   #15
il probably use Singer oil. Would 3-in-1 work? its what i have handy, but im running my car every other day. Just broke it in on monday
Nitro On-Road Addict sa RC Manila Racers 12522 12-27-2015 05:51 PM
After run oil? srowell3 Nitro On-Road 43 02-22-2007 07:51 PM
Tuning Guide for Nitro? K_King Electric Off-Road 6 02-16-2007 03:51 PM
