Old 04-21-2010, 10:27 AM   #16
rc_in_mexico's Avatar
Send a message via MSN to rc_in_mexico Send a message via Yahoo to rc_in_mexico
if WD-40 works for short term, il use it since il probably run all year here in mexico. I might run aluminum tape around the cooling head in the winter since it gets in the low 40s here
rc_in_mexico is offline   Reply With Quote
Old 04-21-2010, 11:52 AM   #17
The fuel I use says no after run oil required for typical use so check your fuel. Remember that when you put in after run oil it will displace some of the oil already on the parts. So next time you start up your engine it is essentially lubed by the after run oil until enough fuel goes through to wash off the after run oil and replace it with regular engine oil from the fuel. So make sure your after run oil is designed not only to prevent corrosion, but also to lube a running engine. this would make me shy away from anything that isn't intended for an engine. I doubt you would get a hard failure like a seizure, but definitely increased wear on the piston, etc..
MattFL is offline   Reply With Quote
Old 04-21-2010, 12:01 PM   #18
DiaRh34's Avatar
Send a message via AIM to DiaRh34
Sidewinder 30%
Taco
Bullet Town raceway Milan, Tn
TLR 8b - Tekin - SMC
DiaRh34 is offline   Reply With Quote
Old 04-21-2010, 12:10 PM   #19
davidfast's Avatar
Trader Rating: 22 (100%+)
What does typical use even mean.....talk about overly subjective wording. Typical use to me isn't typical use to my r/c racing neighbor, nor is typical use to me typical use to Joe the plumber.
davidfast is offline   Reply With Quote
Old 04-21-2010, 12:23 PM   #20
i think typical use is bashing and easy racing. no extreme beating on your engine. i run trinity monster horsepower 20%. should i use no oil then?
Old 04-21-2010, 12:27 PM   #21
davidfast's Avatar
Then they should word it like that. No need to hide behind language.
If the bottle doesn't say specifically to not do it, you should then run after run oil.
Old 04-21-2010, 12:35 PM   #22
thanks. il have to use Singer Oil since i dont have a hobby shop in my state
Old 04-21-2010, 12:36 PM   #23
I will read the exact wording when I get home, but the general message was ARO not required unless it is going to sit unused for a long time.
Old 04-21-2010, 12:43 PM   #24
yea, il probably jus leave it as is. i lost a screw that tightened my engine heatsink and was wondering if i could still use it or wait until i get a ne screw. it uses 4 and i now have 3
Old 04-21-2010, 01:36 PM   #25
JAMMINKRAZY's Avatar
Trader Rating: 17 (100%+)
Don't run it with a missing head screw!
-Koby Kubrin-
Thanks to my Sponsors:
Serpent America | Team Novarossi | Desoto Racing | Race AKA | Ridgeway Bodies
JAMMINKRAZY is offline   Reply With Quote
Old 04-21-2010, 05:50 PM   #26
Here's the exact wording and my attempt at posting a picture of the label:
"After run oil is not required for short-term storage when all remaining fuel inside the engine has been completely used"
Old 04-21-2010, 06:00 PM   #27
I should think so with how much oil is in Traxxass fuel. You're already running twice as much oil through the engine as you should be.
-Koby Kubrin-
Old 04-23-2010, 07:10 PM   #28
found the screw. those magnets you through in the air so they crash pick up everything.
Old 04-23-2010, 07:20 PM   #29
dannyg1970's Avatar
I use Manteca lol
dannyg1970 is offline   Reply With Quote
Old 04-23-2010, 07:29 PM   #30
Questions??
to get lost screws?
Nitro On-Road Addict sa RC Manila Racers 12522 12-27-2015 05:51 PM
After run oil? srowell3 Nitro On-Road 43 02-22-2007 07:51 PM
Tuning Guide for Nitro? K_King Electric Off-Road 6 02-16-2007 03:51 PM
