Old 04-20-2010, 02:24 AM   #1
Default Losi 8 2.0 B grass set up
HI
just wondering if any one here or any one of the team drivers have a good starting set up for grass for the Losi 8ight 2.0 buggy. Also what tyres would you recommend i run.
Any help would be appreciated
Thank You
Deepal
deepal is offline   Reply With Quote
Old 04-20-2010, 06:30 AM   #2
BAUSTIN's Avatar
I would run a standard setup with possibly more ride hight.........
Maybe some Badlands.......they are not made for racing.......but will do well in grass.......
Billy Austin
www.Code3RC.com
Elevation Sports
BAUSTIN is offline   Reply With Quote
Old 04-20-2010, 09:59 AM   #3
Trader Rating: 21 (100%+)
Be sure to use use THICKER clutch springs, there is a TON of traction in grass.
TopGearRC is offline   Reply With Quote
Old 04-20-2010, 02:11 PM   #4
Integra's Avatar
Contact Darren Bloomfield from Team Losi over in the UK....they just ran the BRCA Rd 1 @ Frankly and it was a 100% Astro track.
Or are you talking about real grass ? buggy's dont tend to like the grass very much due to being so low as apposed to say a Truggy or MT which ride quite a bit higher...Grass tends to burn out clutch's and motor's if not tuned for it.
Old 04-20-2010, 03:24 PM   #5
Originally Posted by xjqkz View Post
Be sure to use use lighter clutch springs, there is a TON of traction in grass.
don't you mean heavier springs? that would allow you to take full advantage of the available traction. lighter springs are better for a smoother earlier clutch engagement for use on low traction surfaces.
C.Harper is offline   Reply With Quote
Old 04-20-2010, 05:23 PM   #6
Poltro's Avatar
I dont run a losi but here in WA ( australia ) we run all the time on grass!
1) haveri diff oil ( i ue 10-10-5 )
2) 1.1m springs on the clutch
3) stiffer springs/havier oil
4) thicker sway bars to educe the traction rolling..
But anyway if you run you standard dirt set up yo should be ok anyway.
Tires: shumacher make some good ones but use AKA inserts. Others: turbo rats,angle spike etc. Generally speaking you want to have long pins.
hope this helps..
Bittydesign Australia // Picco Engines Australia// PT Racing Oils // GForce www.nprs.com.au
Poltro is offline   Reply With Quote
Old 04-20-2010, 09:56 PM   #7
yes, thanks fixed
Old 04-20-2010, 10:20 PM   #8
Thanks allot guys will defiantly try those tips out and let you know how i went.
Old 04-21-2010, 07:02 AM   #9
fleggasaurus's Avatar
Hey Dude
I too regularly race on actual grass with our local clubs transportable trailer and piping setup. See www.radiorally.org.au if your interested for a look.
Tyre wise, hobao andle spikes, shumacker spirals or hong nor grass snakes are "the" tyres to run on grass. With grass being such a high traction surface though, you want to run hard inserts such as the aka inserts to take full advantage of the traction.
Setup wise, probably the 3 biggest things i would suggest is stiffer springsall round, heavier rear shock oil to say 30wt, 2.7mm sway bar front, 2.5mm sway bar rear and then you can also play around with your camber linkage positions to compensate for the generally smooth surface.
Motor and clutch wise, I would start with say a 7mm insert, all aluminium shoes and 2 gold and 2 silver springs if running the losi clutch.
If you have them also, the aluminium chasis braces help out also because grass is such high traction. That's a pretty good starting setup and something that I would run first off and take it from there.
Cheers
Fleggy
fleggasaurus is offline   Reply With Quote
Old 04-21-2010, 07:38 AM   #10
Integra's Avatar
fleggasaurus Question for ya....what are all the large lug truggy tires in the pics ? The real Flat Profiled ones ?
Old 07-23-2010, 01:02 AM   #11
tomdex's Avatar
Trader Rating: 4 (83%+)
If they're the ones I think you mean, they're GV Grinders
http://www.rcheadquarters.com.au/15604.html
Tom Dexter - XRAY Luxury Racing Cars - AKA Tyres - OS Engines - Radio Rally Club WA inc.
Aaron Dexter - Proud to be sponsored by HEI-XRAY Australia and AKA Australia-RYPER Hobbies
tomdex is offline   Reply With Quote
Old 07-23-2010, 01:13 AM   #12
808gx7r's Avatar
best tyres for grass are proline stepups...
808gx7r is offline   Reply With Quote
Old 07-23-2010, 08:17 AM   #13
jwm2's Avatar
I've only driven my buggy on grass a few times and it has already worn a track in my yard. My buggy absolutely eats grass up!
jwm2 is offline   Reply With Quote
Old 07-26-2010, 11:52 AM   #14
Integra's Avatar
Truggy not buggy.
Belt Driven vs. Shaft Driven Allen Sondej Electric On-Road 69 11-05-2004 07:51 PM
