Old 04-19-2010, 08:32 PM   #1
Show871's Avatar
Default Traction roll adjustments?
I have my first race coming up....and it seems like when I get on a tacky prepped track, my car traction rolls instead of sliding into a corner nicely. If I get to this track all prepped out and start traction rolling, what are the best adjustments to make? Losi 2.0, cityblock front Ibeam rear, Drake setup
Thanks! 871
Show871 is offline   Reply With Quote
Old 04-19-2010, 08:33 PM   #2
smokinu's Avatar
Trader Rating: 60 (98%+)
lower the ride height and ad a degree or 2 of camber.
Marcus P.
\\Speedzone USA//Savox USA\\Caster Racing Parts//
www.speedzoneusa.com. www.casterracingparts.com
smokinu is offline   Reply With Quote
Old 04-19-2010, 10:28 PM   #3
Trader Rating: 21 (100%+)
Lower ride height would really help with stability. To fine tune it, it will take a lot of trial and errors. Once you find that perfect dialed setup be sure to write it down and also the weather/track conditions.
TopGearRC is offline   Reply With Quote
Old 04-20-2010, 05:16 AM   #4
Try a harder compound tire.
clebo3 is offline   Reply With Quote
Old 04-20-2010, 05:19 AM   #5
LabRat99's Avatar
+1
I would adjust camber first though.
LabRat99 is offline   Reply With Quote
Old 04-20-2010, 06:40 AM   #6
This is your FIRST race? Im gonna say, stop worrying about set up. MY OPINION - learn how to drive and understand setup before you start screwing on stuff in the middle of race day. I run drake standard setup without the V2 (don't like it). But I sure as hell would not try new setups on race day with out knowing what and how it will effect the car. 2 summers ago, I was just sliding all over the place, and 3 Losi drivers told me to slow down, sliding in and out of corners is the second worst way to lose time per lap. According to them, you want traction you can go through corners faster, and accelerate faster out of corners.
That's just what was told to me by PRO drivers and it has made a big difference, I can actually some what hold a line with out sliding all over the place.
I'm not sponsored so it does not matter what I put here.
Shuming is offline   Reply With Quote
Old 04-20-2010, 09:27 AM   #7
DOMIT's Avatar
Location: Fort Worth, Texas, USA, North America, Earth, Solar System, Milky Way Galaxy, Universe
Send a message via MSN to DOMIT Send a message via Yahoo to DOMIT
Try slowing down in the corners.
If you really want it to slide, you can try any of these: take some droop out of the rear, stiffer swaybar, less rear toe, stiffer rear shocks, rear brake bias, shorter rear camber link, lower the inside end of the rear camber link... any of those will take away rear side-bite.
Frankly, you have a problem that I only wish I had. Too much traction is against my religion! I don't believe there is such a thing!
Brad "DOMIT" Smith - I'm not fast, but at least I wreck a lot.
Unsponsored, but I use/recommend: XRay XB9, Alpha A852, Dynamite 053, Airtronics M11, Hitec 5955TG & 7955TG, ABEC 35 clutch and chassis bearings, PTRCRacing shock and diff fluids, Ready Rollers ceramic engine bearings. ** Team Terribles Region 9 coordinator. ** JOIN TEAM TERRIBLES! All racers welcome! PM me for details.
DOMIT is offline   Reply With Quote
Old 04-20-2010, 10:03 AM   #8
+100000000000000. Be a lot smoother on the steering inputs as well. This will help you in both tacky and dry conditions.
TPJ International
071crazy is offline   Reply With Quote
Old 04-20-2010, 11:06 AM   #9
jpz_67's Avatar
Trader Rating: 56 (100%+)
Take the front brake rotor off.
Agama A215, Futaba, Nitro Pro Fuel, Proline tires, Triton Engines, Savox.
jpz_67 is offline   Reply With Quote
Old 04-20-2010, 01:51 PM   #10
Charles Godwin's Avatar
You obviously haven't driven on astro-turf . If it is rolling whilst going into a corner try and focus hard on how the suspension is working. It might be so stiff that it has no chance to compress and absorb the grip. Then again it might be sooooo 'wallowy' (sp?) that it flips and rolls over. Best bet would be to use a small pin tyre or cut blocks/spikes off the outside of each tyre. As said try stiffer roll bars, heavier oil in the shocks etc.
DXR | CML Distribution | Paint by Turnip Paint | TKRgraphics.com
Charles Godwin is offline   Reply With Quote
Old 04-20-2010, 01:51 PM   #11
DOMIT's Avatar
Let's hope he doesn't take that seriously...
Old 04-20-2010, 05:44 PM   #12
It's your 1st race have fun and go slower than you think you should.Just make it around the track and stay calm if you can.I was in your shoes a year ago in the nitro department,and didn't even know there was so much to dial in on a nitro car.I have surely learned alot this past year, as will you,there are alot of good people in this sport that will teach you.I'm no pro just my 2cents.
The fisherman is offline   Reply With Quote
Old 04-20-2010, 07:05 PM   #13
Show871's Avatar
Hey thanks for all the help....It will help alot!
Old 04-20-2010, 07:22 PM   #14
Wider hubs, stiffer sway bars, harder tires, move the shocks to the outer hole on the arms, less rear toe and more camber..
gasser is offline   Reply With Quote
Old 04-20-2010, 11:37 PM   #15
v6shooter's Avatar
my first adjustment is more camber.
v6shooter is offline   Reply With Quote
Traction Roll ? gansei Nitro On-Road 75 10-11-2012 11:38 PM
traction roll......help hacker Electric Off-Road 12 04-03-2009 06:34 PM
Traction roll cures? mtbboy Electric On-Road 30 01-17-2009 07:03 AM
Rubber Tire Traction Reduction raffaelli Electric On-Road 10 01-09-2007 09:10 AM
