Old 04-19-2010, 07:03 PM   #1
metalartcustoms's Avatar
Default Rc8t steering block screws
Hey all. I am not sure if anyone else has had this problem but I keep losing the screws on the bottom of the steering blocks. I have tried loc tite. If I torque them down then I can't turn. Any thoughts on a way to keep these in?
metalartcustoms is offline   Reply With Quote
Old 04-19-2010, 07:30 PM   #2
Shane Racer's Avatar
You may have the inserts in wrong. The short insert and short bolt go on the top and the long ones go in the bottom. If you have the short ones in the bottom then that makes sense if you tighten it down it will not move.
KYOSHO AMERICA-Novarossi-M2C racing-Competition Heat-Grandview Hobbies-Fastraxx Hobbies-TKO-Clockwork-The Ohio RC Factory
Shane Racer is offline   Reply With Quote
Old 04-19-2010, 11:01 PM   #3
Oh I can chime in here...
I was having the same issues, was losing about 1 a week on either the T or the B. Here is what I do and have not had an issue since. First, as stated earlier make sure they are installed correctly. So here is what I do:
1. Apply blue loctite to screws liberally on the last 1/4 or so of the screw, get a blob kinda
2. Using pliers to hold the bolt, use a lighter, light the loctite and let it burn down a bit (20-45 secs), will turn black, set the screw aside (caution it will be hot) and let the loctite harden a bit.
3. Insert screw and forget about it
Yes you can still remove the screw after doing it this way, I have not lost one yet since doing so.
Tekno NB48 Samurai Proline Tires
Tekno NT48 XZB Speed Proline Tires
Tekno EB48.3 Viper Proline Tires
Tekno / Dialed RC Hobbies / TKO Competition Development /
Stirex is offline   Reply With Quote
FS: rc8t brushless tekin rx8 dx3s zippy 5s lipos hootie7159 R/C Items: For Sale/Trade 29 07-14-2009 10:16 PM
FS: 2x RC8T's 12a_rx2 Australia For Sale/Trade 36 06-23-2009 04:37 AM
