Old 04-19-2010, 09:50 AM   #1
Trader Rating: 34 (100%+)
Default Yellow Corrugated Tubing
Does anyone know where the tracks that have the yellow tubing are getting theirs from? We are looking to do the same here and I cannot find a source for any.
Smith90 is offline   Reply With Quote
Old 04-19-2010, 09:51 AM   #2
MadRussian's Avatar
Do a search, someone else asked that and I posted like 5 different places to get it
MadRussian is offline   Reply With Quote
Old 04-19-2010, 10:01 AM   #3
care to give me a hint on the key words. Ive tried yellow and corrugated and tubing with no luck
Old 04-19-2010, 10:05 AM   #4
neobart's Avatar
Do a search for corrugated drainpipe. Make sure it's UV resistant, or it will get very brittle very fast in the sun.
Clockwork Racing Engines
neobart is offline   Reply With Quote
Old 04-19-2010, 10:21 AM   #5
MadRussian's Avatar
What is the white pipe bordering the nitro pit?
Old 04-19-2010, 01:31 PM   #6
http://www.baughmantile.com/polycap1.htm
slow is offline   Reply With Quote
Old 04-19-2010, 01:33 PM   #7
RUNNINONMT's Avatar
coragated or acordian like conduit
RUNNINONMT is offline   Reply With Quote
Old 04-19-2010, 02:47 PM   #8
sleek's Avatar
You may also check your local lumber yard, I've seen it there before and I personally have bought it at places like farm and fleet or tractor supply type places if you have those around your area...hopes this helps
sleek is offline   Reply With Quote
Old 04-19-2010, 03:11 PM   #9
Sleek, have you seen the yellow stuff at Farm n Fleet or Tractor supply. I've only seen the black stuff at the stores by me.
Old 04-19-2010, 05:44 PM   #10
DiaRh34's Avatar
Send a message via AIM to DiaRh34
Our track is at a public park and they had it around the fences for the baseball fields but they started getting wasp nests in them so they gave us a bunch for the track
Taco
Bullet Town raceway Milan, Tn
TLR 8b - Tekin - SMC
DiaRh34 is offline   Reply With Quote
Old 04-19-2010, 07:19 PM   #11
8ight-racer's Avatar
Just curious, what are the advantages over the yellow pipe over the white pipe and 3" corrugated pipe? Right now our track has the 3" black flex pipe and over 6 weekends it has gotten torn apart in some areas. We have the white pipe and that should be much better as well as more visible, so why would you want the yellow pipe over the white pipe?
Palm Desert R/C Raceway - www.palmdesertrcraceway.com
JQ Products, Pro-Line, TKO, Buku, Werks Fuel, Savox, A Main Hobbies, and Uncle Don's Hobbies
8ight-racer is offline   Reply With Quote
Old 04-26-2010, 11:33 AM   #12
Super Moderator
Brandon Rohde's Avatar
Baughman Tile Co. is who makes the yellow corrugated tubing. The stuff you want for an r/c track is the 4" non-perforated:
http://www.baughmantile.com/nonperforated.htm
Their price is $0.35/foot if you go there and get it direct. It doesn't matter if you get a 100 foot or 250 foot roll, or if you get 1 roll or 20 rolls. Its a straight up $0.35/foot, so its easy to figure out how much it costs.
If you don't want to drive there and live in the midwest, Carter Lumber is one of their distributors. http://www.carterlumber.com They have stores around the northern midwest. Generally it is marked up 40-50% at hardware stores though, so going direct is your best bet. I was able to fit 9 rolls of 250' tubing in a 16x7 foot trailer and the bed of my truck.
If you don't live around there, ask your hardware store if they can get product from Baughman Tile. Otherwise, it is often marked under the "Poly-Drain" line of products in their catalogs. Its the same stuff from the same place.
Brandon Rohde
LiveRC.com
Brandon Rohde is offline   Reply With Quote
Old 04-08-2012, 05:38 PM   #13
Thank you for the great information.
I am doing a track at Michigan International Speedway in May and this is just what I needed to help make it happen.
Dan's Machining & Welding
Washtenaw RC Raceway Michigans Biggest and Best Indoor Dirt Racing.
Tekin
DJ1978 is offline   Reply With Quote
Old 04-08-2012, 06:24 PM   #14
We use the yellow on our track, and it was way more expensive then the black or white. It also seems to feel thinner then the others. It does look cool, but we are planning to start switching to the white this summer, as we replace the yellow that's worn out.
bevofrancis is offline   Reply With Quote
Old 04-08-2012, 10:06 PM   #15
neobart's Avatar
My track switched to 80mm and 100mm mooring rope. Very easy on the cars, and doesn't mind cold, heat or the sun. And it lasts forever. It's been down two years now, and still looks great.
