Old 04-19-2010, 07:58 AM   #1
Rich Panganiban's Avatar
Trader Rating: 72 (100%+)
Default Any idead on how to remove stripped engine head screws?
I stripped one of the screws on my O.S. V-Spec this weekend...argh!!!
Any suggestions on how to remove that stripped screw?
Thanks in advance for any "constructive" suggestions.
Rich Panganiban is offline   Reply With Quote
Old 04-19-2010, 08:00 AM   #2
MotoGod's Avatar
Trader Rating: 112 (100%+)
Send a message via AIM to MotoGod Send a message via Yahoo to MotoGod
Drill it out or use a screw extractor if you can get it through the hole in the head. I had this happen to me on an RB Engine....took some time, but I drilled off the head of the stripped bolt carefully and all was well again.
Scott Pouliot
Current Race Rigs: TLR 8ight 3.0/3.0E/3.0T/22/22-4
Thanks to my 2015 Sponsors: LutzRC, RadioPost, AKA Tires, RC Addition Products, Nitro Pro Fuels
MotoGod is offline   Reply With Quote
Old 04-19-2010, 08:10 AM   #3
Location: 4373 Creek Road Chaffee,NY 14030 USA (716)783-5198
Trader Rating: 23 (100%+)
Default left hand drill bit
Get your hands on a set of left hand drill bit. works like a champNext best thing to EDM, burning out. remember reverse drill direction
Good luck....
RayAracing piston+sleeve reconditioning-resizing Tooling+Services ALL Buggy, Truggy, Car, and Truck engine models .12 thru .50 since 2001
SHIPPING:4373 Creek Road, Chaffee, NY 14030 USA
PHONE: (716)783-5198 EMAIL: RayA@RayAracing.com SERVICE: http://www.rayaracing.com/
TOOLING: http://www.rayaracing.com/prodtooling.htm
RayA is offline   Reply With Quote
Old 04-19-2010, 08:22 AM   #4
sugs's Avatar
I've never owned a Vspec, so I don't know if you can do this with one but I've done it before with other engines. If you can get at the head of the bolt through one of the slots between heatsink fins with a cutoff wheel on a dremel, then cut if off. Should be able to then get the heatsink off and dremel a slot in the screw and back it out.
- Associated B4.1 Worlds -
- Associated SC10 FT -
- Associated SC10 4x4 -
- Mugen MBX6 Alpha F850 -
- Nomadio Sensor - Hitec servos - Panther tires - DE Racing -
sugs is offline   Reply With Quote
Old 04-19-2010, 01:36 PM   #5
shady3031's Avatar
Trader Rating: 26 (100%+)
I helped a buddy do this at the SIC in Alabama last year. We took a drill bit and drilled through the head of the bolt, when the head of the bolt breaks off, the head will come off over the threaded part of the bolt. Then you can use a pair of pliers to remove the threaded part. I have done this numerous times and it always works, just take your time, you may want to start with a smaller size bit, then increase the size to completely remove the caphead.
Hope this helps and good luck.
The Warehouse RC-Birmingham, AL
AE RC8.2-E Tekin powered
Alabama Manufacturers Shootout-Don't Miss It
shady3031 is offline   Reply With Quote
Old 05-06-2010, 10:50 AM   #6
Thanks for the drill bit idea. I put a bit in the drill press and it drilled the head of the cap head screw right off. Worked perfectly!
Old 05-06-2010, 11:13 AM   #7
There was an article on this in one of the magazines recently. I'll see if I can find it.
The Wedge is offline   Reply With Quote
Old 05-06-2010, 02:37 PM   #8
takes about 2 minutes with the right size drill bit.
"You are not understanding the fundamental principles of my fragmented personality"
Mugen
dreaux is offline   Reply With Quote
