Old 04-18-2010, 04:26 PM   #1
Trader Rating: 15 (100%+)
Default Return spring?
What are you guys using for throttle return springs? I heard some are using orings? just seeing what most are using.
David Moore, Pikemotorsportsrc.com
Sponsored by:Mugen Seiki, Pro-Line
MBX7, MBX7 eco
drt_racer5 is offline   Reply With Quote
Old 04-18-2010, 04:31 PM   #2
DANE_TRAIN's Avatar
Trader Rating: 20 (100%+)
I use both.
http://www.amainhobbies.com/product_...e-Return-Bands
http://www.amainhobbies.com/product_...-Eyelet-XXX-NT
Pro4mance Hobbies
DANE_TRAIN is offline   Reply With Quote
Old 04-18-2010, 04:36 PM   #3
hdcruzer's Avatar
Nothing, Never had a problem......
Ofna Late Model-Losi 350-Losi RE 10-Hobbico CS170s
Coldfusion Fuel
Henchman Racing
hdcruzer is offline   Reply With Quote
Old 04-18-2010, 04:51 PM   #4
zJatoRad's Avatar
Trader Rating: 31 (97%+)
Send a message via MSN to zJatoRad
This is what I have been using for a while...
http://carolinasrc.com/Webstore/Scri...idproduct=4002
"Smooth is Slow, and Slow is Fast"
zJatoRad is offline   Reply With Quote
Old 04-18-2010, 05:02 PM   #5
DANE_TRAIN's Avatar
I have never had a problem. I use the losi spring to put resistance on the throttle servo making it smoother. Also it has enough tension to close the throttle in case of power loss. I use the GMK rubber bands in case of linkage failure.
Pro4mance Hobbies
Old 04-18-2010, 05:28 PM   #6
JAMMINKRAZY's Avatar
Trader Rating: 17 (100%+)
I use the GMK bands linked above. I usually put about 3 on the carb. Wrap them around the carb with one end over the high speed needle and the other end looped over the linkage ball. Use enough bands so that they will pull the carb completely shut with servo and linkage connected. In other words with the power off you should be able to pull the carb/linkage open and it should completely close itself. This will insure that the carb will close if you have a power failure and will also insure that the carb will close if the linkage ball should ever pop off. It is not only a good practice that can save you lots of trouble if there is a failure, but also is required by many tracks/races.
-Koby Kubrin-
Thanks to my Sponsors:
Serpent America | Team Novarossi | Desoto Racing | Race AKA | Ridgeway Bodies
JAMMINKRAZY is offline   Reply With Quote
Old 04-18-2010, 05:40 PM   #7
pballer2777's Avatar
Trader Rating: 27 (100%+)
i use the losi return spring. it come in the linkage kit from a lst. losa4202
tlr 8 4.0 /rex engine/aka
tlr 8e 3.0/tekin/aka
pballer2777 is offline   Reply With Quote
Old 04-18-2010, 05:59 PM   #8
awdcameolsx's Avatar
Trader Rating: 36 (100%+)
Not to you dude but I have heard that linked to just about every motor blow up runaway I have heard.
But personally what I and every one else I race with does just buys a package of regular elastic bands from the store. I replace them every day because it like $2 for a pack of 1000 or so. Its really cheap insurance that doesn't tax your throttle servo.
Another easy insurance thing is to make sure your switch being in the forward or down position is on so it doesn't shut itself off on a hard hit.
awdcameolsx is offline   Reply With Quote
Old 04-18-2010, 06:32 PM   #9
highvoltage's Avatar
Trader Rating: 139 (99%+)
I went to Wal mart and picked up some black rubber bands for hair. I got like 500 for a dollar or two..
Highvoltage Racing
"1/8 racing parts store"
highvoltage is offline   Reply With Quote
Old 04-18-2010, 08:16 PM   #10
Jon Moore's Avatar
Regular hair bands. Cloth covered ones. I run two, in case one fails.
Jon Moore is offline   Reply With Quote
Old 04-18-2010, 08:55 PM   #11
Trader Rating: 12 (93%+)
my sister is a dentist so she hooks me up with little rubber bands in large ammounts for free!
rcdude236 is offline   Reply With Quote
Old 04-18-2010, 09:18 PM   #12
RCmayor's Avatar
Send a message via Yahoo to RCmayor
+1 on the Dynamite springs, I think the one I have is a different brand but it is the same shape and design. Works perfectly and have been using the same one for 3 years.
RCmayor is offline   Reply With Quote
Old 04-18-2010, 09:42 PM   #13
shanty140's Avatar
Thumbs up
I use 2-3 of those GMK Carb-O's linked above. They have to be replaced every couple races but they give you a lots and for me a pack can easily last the season.
Race Vehicles:
Mugen MBX6T - Ninja JX.21 with EB Mods Headbutton, O.S. 2060 Pipe, DX3R, Hitec 7955TG Servos on LiPo
HPI Cup Racer - Murfdogg Synergy 17.5, Tekin RS Pro, 2S 40C 4200mah, DX3R, Sav÷x SC-1251MG Servo
shanty140 is offline   Reply With Quote
Old 04-18-2010, 09:59 PM   #14
rc skyline's Avatar
Rubber bands. Just put new ones on each race day
Dave
MUGEN MBX7R & MBX6TR
FUSION X ENGINES By Novarossi
BUKU Power Clutch
MECCAMO FUEL - BETA Tires
www.fusionxengines.com.au
rc skyline is offline   Reply With Quote
Old 04-19-2010, 03:09 AM   #15
fattyalan's Avatar
Dave
rubber band for the win....dont get fooled but those rc brand things...go to anystore and get yourself rubber bands
Hot Bodies D8
O.S V-spec EB mods
Spektrum DX3R
Nitro-X Fuel
fattyalan is offline   Reply With Quote
install a throttle return spring Sylvain Nitro Off-Road 32 05-05-2012 11:32 AM
Break return spring wrayth Nitro Off-Road 31 03-25-2010 09:01 PM
Carb return Spring. hdcruzer Nitro Off-Road 19 10-07-2009 02:54 AM
Throttle Return Spring Problem helgso Nitro Off-Road 17 08-10-2009 11:05 AM
Throttle return spring on 1/8 buggy RGraves Nitro Off-Road 40 03-27-2009 05:41 AM
