Old 04-18-2010, 01:30 PM   #1
hdcruzer's Avatar
Default Motor Flame Out
What are the causes for a motor to flame out? Mine has always ran very well and now with the weather warming up it will run fine as long as Im on the trigger but will die some times when I let off. I have richened the HSN a couple of hours and that seems to have worked for now. Any other suggestions.....
Ofna Late Model-Losi 350-Losi RE 10-Hobbico CS170s
Coldfusion Fuel
Henchman Racing
hdcruzer is offline   Reply With Quote
Old 04-18-2010, 01:52 PM   #2
neobart's Avatar
Sounds like it's starving for fuel on the LSN from what you describe, or too much fuel. I know it's kinda vague but it's hard to be more specific, but I suggest you work on the LSN.
Clockwork Racing Engines
neobart is offline   Reply With Quote
Old 04-18-2010, 02:41 PM   #3
Lilja's Avatar
How many gallons did you put through the engine? Cause it could also be that the engine is simply worn out and has low compression.
Serpent S811 Novarossi Plus-4 BTT Futaba BLS451/452
Serpent S811T OS 25XZ Futaba BLS351/352
Serpent 966 Futaba 9451x2
TLR 22 Toro 9.0kv Futaba BLS451
Futaba 4PK
Lilja is offline   Reply With Quote
Old 04-18-2010, 02:47 PM   #4
hdcruzer's Avatar
Exactly, starving for fuel. Has nothing to do with lsn. Your fuel is distributed through the hsn. Leaner less fuel,richer more fuel. Low speed is adjusted to pinch. I pinch, rpms increase slightly and then it dies. Im almost spot on there. If I fatten it up it wont keep an idle at all, if I lean it out idles way to high.......
Coldfusion Fuel
Henchman Racing
Old 04-18-2010, 02:49 PM   #5
hdcruzer's Avatar
Motor only has 2 gallons through it, still has plenty of compression.
Coldfusion Fuel
Henchman Racing
Old 04-18-2010, 02:53 PM   #6
MotoGod's Avatar
Trader Rating: 112 (100%+)
Send a message via AIM to MotoGod Send a message via Yahoo to MotoGod
Idle too low? Old Glow plug? Air Leak?
Scott Pouliot
Current Race Rigs: TLR 8ight 3.0/3.0E/3.0T/22/22-4
Thanks to my 2015 Sponsors: LutzRC, RadioPost, AKA Tires, RC Addition Products, Nitro Pro Fuels
MotoGod is offline   Reply With Quote
Old 04-18-2010, 02:54 PM   #7
Lilja's Avatar
Well perhaps your idle gap isnt correct? If you lean it out a bit and then lower the idle on the idling screw a bit or vice versa.
Futaba 4PK
Old 04-18-2010, 03:07 PM   #8
hdcruzer's Avatar
Air gap is set at about a half mm maybe a hair larger.
Coldfusion Fuel
Henchman Racing
Old 04-18-2010, 05:00 PM   #9
trickedout's Avatar
Trader Rating: 31 (100%+)
hey are you sure your not too rich on top??..when its starts to heat up you need to lean it a bit... usually the hotter it gets outside the more you lean, you might just ben too rich on top and if your low end is a little rich too then your just dumping way to much fuel...when your to rich on top and then let off completly your low end will still be trying to burn the little bit extra from the high speed and that might cause it to flame out going from 100% to 0%
In the middle of some changes
*702 RC Raceway* *WindWater Raceway*
trickedout is offline   Reply With Quote
Flame out on hard landing? Billetboy Nitro Off-Road 7 12-10-2009 02:53 PM
flame out kj racing Nitro Off-Road 6 08-18-2008 04:40 AM
The "Thats it!!! Get the F_*K out of Stock!!!" thread Soviet Electric On-Road 516 03-31-2007 10:30 PM
Engine Flame out issues. Please Help. rodneybarrett Onroad Nitro Engine Zone 24 07-04-2004 08:37 PM
