Old 04-18-2010, 01:09 PM   #1
Default Novarossi carburettor on wrong side
Hi,
I just bougth this Novarossi engine:
http://www.jespares.com/nitro-models...4&keyword=2010
The carburator is on the wrong side and when I install it on my XB808 it doesnt seem to fit right. I am new to this so please help
Jaap is offline   Reply With Quote
Old 04-18-2010, 01:13 PM   #2
yuppi1's Avatar
hi have had no experience with that motor but is there any reason why you cant take the carby off and turn it around?
RC8T - Reedy 121 VR - Spektrum
MOOLOOLA VALLEY RACEWAY
yuppi1 is offline   Reply With Quote
Old 04-18-2010, 01:17 PM   #3
To be honest I have never even started a nitro engine in my life let alone change the carburettor. I will try if I know its possible
Old 04-18-2010, 01:21 PM   #4
shanty140's Avatar
What you need to do is loosen the pinch bolt that holds the carb on the motor. Then gently pull the carb off and turn it the right way. Make sure not to tear the O-rings on the carb when you pull it on and put it back on.
Race Vehicles:
Mugen MBX6T - Ninja JX.21 with EB Mods Headbutton, O.S. 2060 Pipe, DX3R, Hitec 7955TG Servos on LiPo
HPI Cup Racer - Murfdogg Synergy 17.5, Tekin RS Pro, 2S 40C 4200mah, DX3R, Savöx SC-1251MG Servo
shanty140 is offline   Reply With Quote
Old 04-18-2010, 01:24 PM   #5
yuppi1's Avatar
Originally Posted by shanty140 View Post
What you need to do is loosen the pinch bolt that holds the carb on the motor. Then gently pull the carb off and turn it the right way. Make sure not to wreck the O-rings on the carb when you pull it on and put it back on.
+1
also just take your time and be patient, you will it get it
Old 04-18-2010, 01:43 PM   #6
Old 04-18-2010, 01:57 PM   #7
houston's Avatar
Trader Rating: 91 (100%+)
put oil (non petroleum , synthetic) on any area where there is an oring when reassembling . what kind of engine ? does it hapen to be novarossi n21r limited?
TEAM FUSION X ENGINES / TEAM BYRON ORIGINALS / TEAM PROLINE RACING TIRES / TEAM SICK GRAPHICS /TEAM KYOSHO / things I support: COMP HEAT DEALER /TEAM LUNSFORD/ FUSIONX™ USA / TEAM KYOSHO / "H.E.S."™ / BYRON FUELS / RC-OMGUSA/KICWEBDESIGNZ/AKA TIRES/PROLINE RACING TIRES /RAYA RACING/BUKU POWER CLUTCH/M2CRACING/special thanks to STAV and JIM HOTTIGREENMOUNTAINGRILLS.COM
houston is offline   Reply With Quote
