Old 04-18-2010, 10:21 AM   #1
Jaz240's Avatar
Trader Rating: 52 (100%+)
Default Need help finding a specific tool
Do any of you know ( link would be great) if anyone makes a tool that is designed to pop on pop off the ball cup from the throttle linkage to the carb slide? Pliers, screwdrivers, etc put too much stress on the threads and yesterday it cost me a race when my linkage came out of my ball end. Any help will be greatly appreciated.
James Allara
nothing to see here................................
Jaz240 is offline   Reply With Quote
Old 04-18-2010, 10:46 AM   #2
wallot's Avatar
any ball end remover for 1/10 scale cars will do. i do have ball end remover pliers just google ball end remover
DEX408 - Speed Passion Silver Arrow v2, LRP Dynamic 8
Dex410 V3 - Tekin RS Pro, 7.5t Redline
F1-09 - Tekin RS Pro, 17.5t Redline
Sakura Zero S - LRP Quantum, Saturn 20T
KoPropo Eurus
wallot is offline   Reply With Quote
Old 04-18-2010, 11:19 AM   #3
If I'm understanding you correctly, the real-car sized tool for removing ball joints is called a pickle fork. Maybe that's the real name for the tool that Wallot described?
MattFL is offline   Reply With Quote
Old 04-18-2010, 11:35 AM   #4
wallot's Avatar
in rc world it is called ball end remover
KoPropo Eurus
Old 04-18-2010, 11:43 AM   #5
RJNicholson's Avatar
BAM.
Link for RC Ball End Remover. One of the first links google will give you. There are others out there, but here is one. They all look the same basically.
http://www.etamiya.com/shop/ball-end...-90002118.html
*Team Terribles*
Rigs Listed Below
Losi 8IGHT 2.0 B/BCE Chassis/OS VZB *Sleeper*/RE11/JRHV Servos/KHZ
Losi 8IGHT 2.0 B/Werks B7 Pro/2013/Hitech HV Servos
Losi 8IGHT 2.0 E/Mamba Monster ESC/Xcelorin 2100kv or NEU Castle 2650kv *RIP-LIPO FIRE
RJNicholson is offline   Reply With Quote
Old 04-18-2010, 12:04 PM   #6
Jaz240's Avatar
Thank you all for the help. I did not know these things even existed. I found these when I did a search. Its nice to know what I was searching for. These should work great:
http://www.hobbylinc.com/htm/hmx/hmxhmxr4858.htm
Old 04-18-2010, 12:25 PM   #7
Very cool, lean something new every day!
Old 04-18-2010, 02:58 PM   #8
Integra's Avatar
For safety reason's i replace my throttle ball end quite frequently due to popping it on and off all the time....makes me feel a little better about it not happening again (Yes I have been there also james...so dont feel so bad.)
Old 04-18-2010, 03:35 PM   #9
Jaz240's Avatar
What happened to me was from grabbing and bending it off so many times I snapped the rod inside the ball end. Even though my EPA was perfect my servo pulled the rod out of my ball end during my main. I was running 3rd in the final round of the championship series when this happened. My pit man was able to screw it back together and get me back on the track after he burned himself a few times and I had a 300 second lap. I was only able to climb back up 8th so I just ordered that ball link pliers for $20 I think it's well worth it instead of bending and twisting the linkage to pop it off. I have also torn a few carb boots using pliers and screw drivers. I hope that's all in the past with my new fancy tool
Old 04-18-2010, 06:45 PM   #10
J.Sears's Avatar
Does this tool work for putting it on too or is it just for taking it off?
J.Sears is offline   Reply With Quote
Old 04-18-2010, 07:00 PM   #11
Stubbs's Avatar
Trader Rating: 57 (100%+)
This thread is perfect timing....I'veben trying to figure the same thing.
One question though, aren't the pliers for ball link rod ends, not ball cups? I was watching a video on how they're used because I couldn't get my head around how they'd be able to pull off the ball cup on the carb.
Unless I'm missing something, in order for the pliers to work, the little stud on one jaw has to press on the top of the ball, so the other jaw can pop the plastic end off of it. That can't happen with a ball cup since there's no way to press on the top of the ball...
I'm thinking either one of those tapered fork tools, or a small set of curved needle nose pliers are the only two options....and plan on keeping several in my parts bin to replace it often.
Mike Stubblefield - www.capefearraceway.com
"If you're not racing to have fun, then you're doing it WRONG."
"All you need is WD-40 and Duct Tape. If it moves, and it shouldn't, use the Duct Tape. If it doesn't move, and it should, use the WD-40."
Stubbs is offline   Reply With Quote
Old 04-18-2010, 08:42 PM   #12
Jaz240's Avatar
I just ordered it today, so I am not sure yet how it works, but from looking at the photo in the link I posted, I would say that you put the side with the slot over the rod that the ball is attached to and then you would press on the ball link, and for removal you would do the same but instead of pressing the pliers, you would open them and I'm hoping that would remove the ball cup. In theory that would make the best sense, but I wont know for sure until I get them. I will post up info with photos when the tool arrives and let you all know if I wasted $20 or not.
Old 04-18-2010, 08:48 PM   #13
Frank L's Avatar
Trader Rating: 148 (100%+)
James I use these from tamiya.
http://www.amainhobbies.com/product_...ng-Nose-Pliers
All you gotta do is twist and it pops right off. No he-man stuff here I think you got into the "special cannoli" the night before. JK
Old 04-18-2010, 08:52 PM   #14
Jaz240's Avatar
anything I use to grab the ball link and twist it off is no good for me. I want something that will pry the ball cup off the carb without twisting the cup at all, and then pop it back on..My fat little fingers and the limited clearance on the XRAY 808 make it very difficult any other way
