Old 04-18-2010, 04:02 AM   #16
yuppi1's Avatar
not sure i put a new piston and sleeve in straight away
RC8T - Reedy 121 VR - Spektrum
MOOLOOLA VALLEY RACEWAY
yuppi1 is offline   Reply With Quote
Old 04-18-2010, 04:19 AM   #17
I find it unbelievable that engine manufacturers are still useing this groove in the back plate, ive seen some manufacturers giving warnings about this potential problem on their web sites.For them to remove this potential problem they simply remove/ recast back plates with this lump of material not their so it cant get hooked in side the piston like they use to do with just a flat on the top of the back plate like they use to do. Regarding this would increase case volume your not removing any where enough material to make any noticable differerence. Check out how much material was removed when they removed material from the back plate with the 2 areas that were removed to increase transfer channels to which they have gone away from now claiming round is better. Im not suggesting this groove was done in such a way as to break pistons in this way but how many new piston and liners have they sold because of this happening. I know its down to owners to make sure the piston is well above bdc but its very easy for inexperienced people to not do this, Its also quite easy to do this with experience. You forget at times, Put a flat on = no more broken pistons. Martin.
martinh is offline   Reply With Quote
Old 04-18-2010, 04:52 AM   #18
Is this grove in all engines or only the ones in this thread? I am new to the hobby. I have a STS 28 and pulled it apart when new to check it over as I had been advised by a few people. I didn't chip the piston, but this engine may not have this grove or I got lucky and had the piston at or near TDC.
mouse28 is offline   Reply With Quote
Old 04-18-2010, 05:05 AM   #19
It varies on different make of engines as to whether they use a groove or a flat on the back plate. Some engines use shorter conrods and higher wrist pins in the piston to shorten the motors and change the geometry of the motors ie to change rod angles, rod to stroke ratio etc. Which at bdc pulls the piston lower into the bottom of the case so they need a deeper groove or flat for the pist to miss the back plate.
Old 04-18-2010, 05:05 AM   #20
j_blaze14's Avatar
Trader Rating: 34 (100%+)
i fyou rinse the internals of the motor with fuel and grind down the rough edge os the skirt it should be fine.
aGama A8 EVO - Werks B2 - Sidewinder
aGama A8E - TrackStar 150a, 2560kv, 3 and 4 cell
FlySky GT3B, Turnigy HV servos, SKY Lipos
AKA, Proline, Hotbodies Rubber
Elite Performance - HORRC.com
j_blaze14 is offline   Reply With Quote
Old 04-18-2010, 06:26 AM   #21
Brian C's Avatar
Trader Rating: 30 (100%+)
Wow this sucks! Thanks for the thread though. I've pulled several of my engines apart and didn't even think about the piston catching on the backplate. I know I have some that don't have the notch but instead have the indentation so that they can't catch. Seems pretty basic now but hadn't considered it before. As for running the engine with the chipped piston I would think that the assembly is balanced and now the piston is going to be lighter. With the high rpm that they turn I'd worry about it destroying itself. I'd consult a reputeable builder for advice or just take your chances but be willing to grenade the engine. (worst case scenario right!) Sorry for your luck but thanks for sharing.
Brian C is offline   Reply With Quote
Old 04-18-2010, 07:22 AM   #22
NitroFreakManHo's Avatar
Send a message via MSN to NitroFreakManHo Send a message via Skype™ to NitroFreakManHo
Originally Posted by voodoopapa View Post
I can verify that the motor was bdc so its my bad
OUCH! Sorry to hear that bud! Well at least now you know, kind of an expensive way to learn. Bump-start engines' backplates are different than engine with pull or roto starts...best of luck from this point on!
TEAM TERRIBLES √ 2009/2011 SORRCC Points Series Truggy Champ
CRE Werks B5 powered Serpent 811-T
CRE Nova P5 Powered Serpent 811-B
**M2C**Hitec 7955TG Servos**Buku Clutch
www.apaarchery.com www.skoffroad.ca www.youtube.com/nitrofreakmanho
NitroFreakManHo is offline   Reply With Quote
Old 04-18-2010, 07:42 AM   #23
LabRat99's Avatar
I've got a friend who had this happen to him. Since it was an old motor he decided to run it until it blew up. He's been running it for about six months like that and it's still going. It sounds funny though.
I've got no idea if he just got lucky or not but you can try to run them. The gamble is of course that the piston shatters or rod breaks, then the engine is basically a write off.
LabRat99 is offline   Reply With Quote
Old 04-18-2010, 07:53 AM   #24
The engine will probably still run as stated but you will have massive sub piston induction. This is wear the piston goes above the bottom of the exhaust port. Some aero engines are made with sub piston induction which allows the motor to breath better but this is only intended for use with a silencer on the motor. Tuned pipes and sub piston induction does not go well together and should not have sub piston induction. Martin.
