Old 04-16-2010, 08:26 AM   #1
ngk1's Avatar
Trader Rating: 18 (100%+)
Default Losi 1.0 8t problem
I'm having a problem with universal shaft on my 8t on the left side . It making a horrible popping sound at hard throttle. i did notice that the shaft is on the edge of the cup. The right side is fine . This is on the front end. Can anyone help?
ngk1 is offline   Reply With Quote
Old 04-16-2010, 08:33 AM   #2
The shaft could be bent
Your chassis brace may not be tight causing flex
its the gears in the front diff case. replace diff case and inspect gears.
I'm not sponsored so it does not matter what I put here.
Shuming is offline   Reply With Quote
Old 04-16-2010, 08:55 AM   #3
ngk1's Avatar
Default 8t
Thanks shuming i'll look into it
Old 04-16-2010, 12:25 PM   #4
as i re read it - check the bearings and the diff case and the gears in side
Losi 1/8 8ight E 4wd Thread tyhodge07 Electric Off-Road 8898 11-17-2015 05:31 PM
8T 2.0 polarismaster Nitro Off-Road 15880 02-02-2015 10:31 AM
Losi 1/8 Xcelorin Brushless Motor (2100kv) jf45 R/C Items: For Sale/Trade 14 05-22-2009 08:15 PM
losi 8t 1.0 clutch bell bearings giong out rcmandan Nitro Off-Road 14 04-16-2009 04:32 PM
