Old 04-16-2010, 11:04 AM   #16
lewis666's Avatar
Send a message via MSN to lewis666
Originally Posted by Stanton View Post
. Hole shots are a great alll around tire for you. M3 compound w/new black inserts and you should be balancing. I'll stop here as I know there's a lot of info.
Let me know if you have success and I'lll gladly give more advice. Good Luck!
i have tried some proline holeshots they had a very hard tire insert (bought them with a set) they worked well but they only last me two race meetings and i have been talking to friends at my local track and they say that a soft inserts are good for the track some have have had them going for six meetings and they are still in good condition
many thanks for the advise i will give it a try with the set screws in the a-arms
Durango DEX410R, BCE Losi 8ight 1.5 (radical 621t), Durango DESC410R on the way!
radical engines- www.gotnitroonline.com
Got nitro team driver
lewis666 is offline   Reply With Quote
Old 04-16-2010, 01:04 PM   #17
I would try different tires first. Another thing is, buggys are very sensitive to ride height and droop changes. I would try raising the front 1mm and lowering the rear 1 mm if you're doing trackside changes.
Shaun Davis
VP ProUSA
Mugen Seiki/Alpha Engines
Team Trinity
Miniracer23 is offline   Reply With Quote
Old 04-16-2010, 04:04 PM   #18
jrwoodchuck's Avatar
i run 5-5-7 in my 2.0. sounds crazy but it's frikin stuck!!!!!
Doug
TLR 22/M-11
“Looks like I picked the wrong week to quit sniffing glue.”
jrwoodchuck is offline   Reply With Quote
Old 04-16-2010, 11:35 PM   #19
scwrod's Avatar
You may have a good setup and you are just turning the wheel to hard. I had this trouble with the ACE servos(very fast).
Try a drastic amount of -exponential and see if you like it. This is a quick thing to try. If you still do not like it the you will have to chase a setup one thing at a time
hbracing.com tritonrc.com raceaka.com
scwrod is offline   Reply With Quote
Old 04-17-2010, 12:19 AM   #20
lewis666's Avatar
many thanks for the replys i will try some changes
Old 04-17-2010, 02:17 AM   #21
Ananda Robinson's Avatar
Originally Posted by DOMIT View Post
First, remember to change ONE THING AT A TIME and note the results.
Exactly
I had the same issue changed to 1000 in the rear diff and the rear end was planted, also make sure you're running the right tires.
Losi 8ight 2.0.
Losi 8ight-T 2.0.
Ananda Robinson is offline   Reply With Quote
Old 04-19-2010, 05:12 AM   #22
DOMIT's Avatar
Location: Fort Worth, Texas, USA, North America, Earth, Solar System, Milky Way Galaxy, Universe
Send a message via MSN to DOMIT Send a message via Yahoo to DOMIT
I liked my 1.0 with 5-5-5 so it doesn't sound crazy to me.
And remember, try ONE thing at a time...
Brad "DOMIT" Smith - I'm not fast, but at least I wreck a lot.
Unsponsored, but I use/recommend: XRay XB9, Alpha A852, Dynamite 053, Airtronics M11, Hitec 5955TG & 7955TG, ABEC 35 clutch and chassis bearings, PTRCRacing shock and diff fluids, Ready Rollers ceramic engine bearings. ** Team Terribles Region 9 coordinator. ** JOIN TEAM TERRIBLES! All racers welcome! PM me for details.
DOMIT is offline   Reply With Quote
Old 04-19-2010, 05:19 AM   #23
Trader Rating: 68 (100%+)
Didn't see anyone mention clutch. You may have to much snap in the clutch as well. Smoother clutch with a smooth throttle finger will help more than anything.
Dealer for Serpent, Intech, Agama, Pro Speed, JQ Products, Tekno
Alpha,Triton, Picco, Reds, Go, Arrow,Bullitt,Beta
Sponsor- Nemo Racing.
Greg B is offline   Reply With Quote
Old 04-19-2010, 05:27 AM   #24
bobbyblaze's Avatar
Send a message via Yahoo to bobbyblaze
+1 thats an good idea
Arrma Nero 6s, Ofna DM-1 Pro
Traxxas Revo 3.3, Traxxas T-Maxx 3.3, Traxxas Jato 3.3
Traxxas Slash Platinum, Traxxas Slash 2WD
Bend The Rules--Rule The Bends
bobbyblaze is offline   Reply With Quote
Old 04-19-2010, 05:46 AM   #25
lewis666's Avatar
it has been working well until i made some changes to help my car more stable on the bumps along the straight at my local track. would making the camber links longer help because i have made them shorter? and would putting more toe-in at the back help?
Old 04-19-2010, 10:15 AM   #26
Trader Rating: 30 (100%+)
longer rear links will make for less camber change so should help a little toe in helps on power keeping the car straight should have 3 deg. toe in back and either 2 or 2 deg of anti squat what is the exact set up you are running right now diffs and links ride height i fhave 7000 in your middle diff. should try 5000 in back 3000 should be good 5000 in the front also if still to loose try running green and black clutch springs on blue and composite shoes pros like to run the softer clutch setup at tracks where the traction is a problem but have found that the softer clutch setup for non pro drivers just makes the car better to drive so would try those things one at a time until get it the way you want it if change evedrything at onnce car will feel totally different and wont no what did what if you dont like it i would start in this order
longer rear upper link
3 deg. toe in
5-5-3 diffs.
softer clutch setup
also try running all the back wheel base set up for rear hubs
jewn_beef is offline   Reply With Quote
EPMTs check in here. (a subsidiary of TNT) overtki11 Singapore R/C Racers 55470 05-07-2017 11:57 PM
Losi XXX-S TSR6 Electric On-Road 14329 01-26-2015 07:59 PM
Tamiya TRF416 / TRF416WE / TRF416X academygaz Electric On-Road 10619 01-01-2015 03:36 PM
World Championship for GP 1/10 fatboy Malaysian R/C Racers 45 08-19-2008 08:27 PM
