Old 04-15-2010, 07:19 PM   #1
Default engine cutting out in mid air?
I have and rc8 rtr with the .28 pro engine in it. Today it started reving real high and shutting off in mid air. Almost everytime I hit a decent sized jump it would just rev out like I was at full throttle the die. I have about 2 gallons through it. I haven't ran it hot, about 210-230, and have it tuned pretty good.
For the life of me I can't figure out whats wrong. Does anyone have any ideas?
bevofrancis is offline   Reply With Quote
Old 04-15-2010, 07:24 PM   #2
jrwoodchuck's Avatar
you're to lean on bottom. the high end is most likely to rich, masking the lean issue on bottom. a common issue.
Doug
TLR 22/M-11
“Looks like I picked the wrong week to quit sniffing glue.”
jrwoodchuck is offline   Reply With Quote
Old 04-15-2010, 07:46 PM   #3
Yup, lean on bottom.It could be an air leak but probably just misstuned. Good luck.
pete 26 is offline   Reply With Quote
Old 04-15-2010, 07:50 PM   #4
RUNNINONMT's Avatar
Default LEAK
+1 on air leak check back plate common place for leaks and make you clean your air filter too.
RUNNINONMT is offline   Reply With Quote
Old 04-15-2010, 07:55 PM   #5
Quickest help ever. Thanks guys, I'll richen the bottom a little and see if that fixes it. I checked for airleaks today and found one. My tube going to the exhast had gotten torn on the flywheel. I replaced that though and ran it for about 20 seconds and my last humpack died. Hopefully that was my problem. My bottom end could be lean though. It's set about 2 turns in from the factory settings, but until it got in that far, the car wouldn't run. I'll back it up some and see if that helps me.
Old 04-15-2010, 10:12 PM   #6
That was definitely the issue. Throw away the current glow plug. The coils will be distorted from running lean. It will not tune properly. Throw a new plug in it and start over.
Kyosho ST-RR, with full lightweight treatment.
JL .21 Extreme RC Modifed
Backup; Trinity Fully "Draked" .21, 7 gallons and counting!
Futaba 3PM-MX, Hitec and JR digi's
VP-Pro tires
ScroggJL21 is offline   Reply With Quote
Old 04-15-2010, 11:22 PM   #7
ScottyM's Avatar
Trader Rating: 27 (100%+)
Agreed.. A torn pressure line will cause too little fuel to make it to the carb.. Don't retune until you replace the line and have a chance to run it again..
Scott Musgrave
ScottyM is offline   Reply With Quote
Engine Tuning 101 (General Tuning) Kemorc Onroad Nitro Engine Zone 41 11-19-2007 06:04 PM
