Old 04-14-2010, 05:09 PM   #1
newuserlosi8t's Avatar
Trader Rating: 65 (97%+)
Default why does my motor keep dying
i have a losi 8ight buggy with a mach 427 it will run like a bat out of hell it will idle forever but when i apply the brake for more then 3 or 4 seconds my motor will shut off frustrated
what should i try
zo1b team option buggy
mg66 go 2072 a main fuels savox servos
TEAM DRIVER FOR----ANSWERRC-USA--- PREMIEREHOBBIES--answerrcusa.com-http://premierehobbies.com ***Contact me for pricing and information on Argus, Hyperion, Max Amps, Durango and Savox***
newuserlosi8t is offline   Reply With Quote
Old 04-14-2010, 05:13 PM   #2
thisguy2849's Avatar
Try turning in your idle screw a 1/16th of a turn. Sounds like the carb opening is closing to much when u hold the breaks.
thisguy2849 is offline   Reply With Quote
Old 04-14-2010, 05:15 PM   #3
ime sorry ime new to nitro and by "" idle screw do u mean the high speed needle
Old 04-14-2010, 05:20 PM   #4
Trader Rating: 520 (100%+)
No, the Idle adjustment screw is usually on the neck of the carb. .It's the lower one right below the high speed screw in this pic..
flame56mx is offline   Reply With Quote
Old 04-14-2010, 05:24 PM   #5
so try 1/16th clock or counter clockwise
ime asuming clockwise
Old 04-14-2010, 05:29 PM   #6
Yeah, clockwise raises idle speed..
Old 04-14-2010, 05:32 PM   #7
thanks man will go give it a run in the morning and hope for the best once again thanks alot man
Old 04-14-2010, 05:52 PM   #8
shanty140's Avatar
When you do this, make sure you check your linkage and make sure it's set correct. There should be a spring on the throttle linkage that pushes back on the carb to make sure the carb is resting on the idle screw and there isn't play when you apply to the breaks. The way to check this is after adjusting the idle screw to get the idle gap you want. Look at the carb and see if the carb closes at all when you apply the brakes. If it does, you need to either adjust you linkage length on the throttle part, or adjust the spring to get pressure against the carb. You will obviously need to remove you carb when you do all of this. You will want about a 0.6mm-1.0mm idle gap. If it's something like 2.0mm for the car to stay running you may need to adjust you low speed needle and lean it out. But if after you adjust your idle gap and it doesn't get smaller after you apply the brakes, you should be good to go. Sorry if this is hard to understand, it is type out on my iPhone. If you need a little more detail of what to do I will get a picture of my linkage and try to explain further. We can also PM each other if you need more detail.
Race Vehicles:
Mugen MBX6T - Ninja JX.21 with EB Mods Headbutton, O.S. 2060 Pipe, DX3R, Hitec 7955TG Servos on LiPo
HPI Cup Racer - Murfdogg Synergy 17.5, Tekin RS Pro, 2S 40C 4200mah, DX3R, Sav÷x SC-1251MG Servo
shanty140 is offline   Reply With Quote
Old 04-14-2010, 06:20 PM   #9
thanks i understand u explained great i added u to my contacts to reffrence this thanks again
Old 04-14-2010, 10:33 PM   #10
merdith6's Avatar
Default Check the clutch tooo......
Sometimes the clutch springs get well unsprung, saggy, streatched, old, tired, sad or just plain beat. That will cause that problem sometimes.
Mad Dog drives a Mugen MBX-7, Novarossi engines, Clockwork Racing, Futaba radio, AKA/Proline Tires
merdith6 is offline   Reply With Quote
Old 04-15-2010, 07:55 AM   #11
DOMIT's Avatar
Location: Fort Worth, Texas, USA, North America, Earth, Solar System, Milky Way Galaxy, Universe
Send a message via MSN to DOMIT Send a message via Yahoo to DOMIT
+1... sort of... if it dies immediately when you hit the brakes... then it is probably this and not the idle... but your problem sounds like the radio is holding idle for you until you hit brakes... so adjust the idle screw, and trim the radio so it is NOT holding the idle up.
Brad "DOMIT" Smith - I'm not fast, but at least I wreck a lot.
Unsponsored, but I use/recommend: XRay XB9, Alpha A852, Dynamite 053, Airtronics M11, Hitec 5955TG & 7955TG, ABEC 35 clutch and chassis bearings, PTRCRacing shock and diff fluids, Ready Rollers ceramic engine bearings. ** Team Terribles Region 9 coordinator. ** JOIN TEAM TERRIBLES! All racers welcome! PM me for details.
DOMIT is offline   Reply With Quote
Old 04-15-2010, 08:11 AM   #12
Trader Rating: 21 (100%+)
also if the clutch bearing is seized it will stop the flywheel when the car stops, so make sure that the CB is spinning freely.
TopGearRC is offline   Reply With Quote
Old 04-15-2010, 08:38 AM   #13
hey cb is good clutch shoes are preety worn and time to replace so i am going to get new cb and shoes and give her a shot
Old 04-15-2010, 11:54 AM   #14
Lille-bror's Avatar
Hi.
Take a look at the video linked in this thread. There you learn the basic adjustment for the engine.
"the tuning bible"
Have fun
www.xray-shop.dk www.northtq.com
Best regards Bjarne Petersson, Denmark
XRAY / FX Racing Engines / OS Speed / HPI / Byron / HUDY / Proline / Sanwa MT4s / Sav÷x servos / Ultimate
I miss you Amy...
Lille-bror is offline   Reply With Quote
Old 04-15-2010, 05:48 PM   #15
boxhead's Avatar
I had a similar problem in that my car would not idle, If I left the glow starter connected then it would. I replaced the glow plug and problem fixed.
I think my glow plug was not holding enough heat to help in the compression ignition these engine require.
Anyway, if you can not see anything obvious try that.
boxhead is offline   Reply With Quote
ALPHA OFF ROAD ENGINES RC Pro Aus Offroad Nitro Engine Forum 11178 Yesterday 04:13 AM
Ernest Provetti Open letter to RC Industry stonedgti Electric On-Road 330 03-24-2010 09:29 AM
Just got off phone with HPI in regads to Savage Flux Lipo's, gears, NIMH and diffs Freezebyte Monster Trucks 50 09-28-2009 12:04 PM
