Old 04-13-2010, 02:09 PM   #1
Default Losi 8ight t 2.0 RTR Problem
I decided today was the day that I would break in my Losi 8ight t 2.0 RTR and before i put fuel in the engine i binded the remote with the bind plug. I turned on all power and turned the steering wheel clockwise and nothing. I turned it left and the wheels turned all the way left and did not return to center and I was unable to return them to the center either. I havent even put gas in the fuel tank yet and I dont know what is wrong with the steering. Any help would be appreciated!
Jato3.3NJ is offline   Reply With Quote
Old 04-13-2010, 02:19 PM   #2
pickle311's Avatar
Trader Rating: 31 (100%+)
Probably a bad steering servo, they don't last long.
With everything off, can you turn the front wheels left to right freely minus the drag from the servo? I doubt something is binding, but you never know.
You can also try removing the servo horn, turn everything on, and see what happens.
Start with the basics though. Did you charge the receiver pack first? It really sounds like the batteries are dead.
pickle311 is offline   Reply With Quote
Old 04-13-2010, 02:34 PM   #3
I charged the receiver pack fully, and get nothing, i will recharge receiver pack again tonight and try in the morning.
Old 04-13-2010, 03:21 PM   #4
DiaRh34's Avatar
Send a message via AIM to DiaRh34
Does it do this while its on the ground? Will it work right if the wheels are lifted in the air?
If this is the case, its a bad servo. I would no be surprised for the same thing happen with my 2.0b rtr. Horizon should replace the servo (they did for me) but it will just happen again. I ended up getting a nice steering servo and moving the stock one to the throttle.
Taco
Bullet Town raceway Milan, Tn
TLR 8b - Tekin - SMC
DiaRh34 is offline   Reply With Quote
Old 04-13-2010, 03:45 PM   #5
hdcruzer's Avatar
Why did you bind it? There bound from the factory. Alls you had to do was turn it on and it should have worked fine. The only reason they give you the bind plug is if you want to bind your control to another car......
Ofna Late Model-Losi 350-Losi RE 10-Hobbico CS170s
Coldfusion Fuel
Henchman Racing
hdcruzer is offline   Reply With Quote
Old 04-13-2010, 04:30 PM   #6
DiaRh34's Avatar
yeah that too, I never bound mine when i got it
Taco
Old 04-13-2010, 06:44 PM   #7
So what was your pick for the steering servo.
same boat
luckypunk is offline   Reply With Quote
Old 04-13-2010, 07:38 PM   #8
DiaRh34's Avatar
Ace 1313, still going strong (knock on wood).
Taco
Old 04-25-2010, 06:39 PM   #9
I'm having the same exact problem with my steering. This is after a day of babying it in a parking lot. I'm just going to order the same Hitec you got and be done with it. I still want this one replaced though since I paid for it. Did you get it replaced?
The Wedge is offline   Reply With Quote
Old 04-25-2010, 06:57 PM   #10
DiaRh34's Avatar
Horizon should replace it if you've not had it long, especially if you just now broke it in. I suggest getting it replaced and using it on throttle. It will not last long as steering, trust me a new good servo makes a world of difference in handling and your driving
Taco
BCE speed Losi 8ight "T" 2.0 3mm chassis xxxtcr Nitro Off-Road 246 08-02-2013 08:44 PM
Losi 8ight T 1.0 or 8ight T 2.0 RTR tootall2 Nitro Off-Road 10 10-09-2009 03:54 PM
losi 8ight t 2.0 rtr Brad.R Nitro Off-Road 9 07-11-2009 06:45 AM
8ight-t 2.0 rtr??? 1cougar1 Nitro Off-Road 28 06-04-2009 09:00 PM
