Old 04-11-2010, 05:22 PM   #1
dishsoap's Avatar
Default Engine Flaming?
Hey guys. Any idea on what you think the problem could be.
I am running a trinity extech .21. It has been run for over 1 year every race that I have attended. Guessing about 7 to 9 gallons of fuel through it if not more.
The idle is fine power is fine and runs great until it gets to temp. Once it gets to temp around the 8th or 9th lap if it sits with no gas for more than 3 seconds it will flame. Only will flame once it gets to temp otherwise will idle forever.
I did notice the front bearing is leaking slightly. Could this be it?
Thanks guys.
HobbyTown USA Tucson!!! HobbyTown USA SRS!!!!
dishsoap is offline   Reply With Quote
Old 04-11-2010, 05:25 PM   #2
houston's Avatar
Trader Rating: 91 (100%+)
Thanks guys.
hows the compression bro?
TEAM FUSION X ENGINES / TEAM BYRON ORIGINALS / TEAM PROLINE RACING TIRES / TEAM SICK GRAPHICS /TEAM KYOSHO / things I support: COMP HEAT DEALER /TEAM LUNSFORD/ FUSIONX™ USA / TEAM KYOSHO / "H.E.S."™ / BYRON FUELS / RC-OMGUSA/KICWEBDESIGNZ/AKA TIRES/PROLINE RACING TIRES /RAYA RACING/BUKU POWER CLUTCH/M2CRACING/special thanks to STAV and JIM HOTTIGREENMOUNTAINGRILLS.COM
houston is offline   Reply With Quote
Old 04-11-2010, 05:27 PM   #3
jpalessi's Avatar
Trader Rating: 55 (100%+)
Send a message via AIM to jpalessi Send a message via Skype™ to jpalessi
Thanks guys.
if its not the tune, its most likely lack of compression. when the compression is low the engine will have a hard time idling. this is the #1 sign of it being time for a new engine. Not too many ppl get there engines to this point cause most end up with some sort of premature failure from lack of attention.
Joe Alessi
www.Lucky7RC.com
jpalessi is offline   Reply With Quote
Old 04-11-2010, 05:29 PM   #4
JAMMINKRAZY's Avatar
Trader Rating: 17 (100%+)
Agreed. Check your compression. If the tune is good that would be the number 1 thing to look for IMO.
-Koby Kubrin-
Thanks to my Sponsors:
Serpent America | Team Novarossi | Desoto Racing | Race AKA | Ridgeway Bodies
JAMMINKRAZY is offline   Reply With Quote
Old 04-11-2010, 05:45 PM   #5
dishsoap's Avatar
Guys. Compression is great. It still takes some good effort to spin it all the way around. When the piston gets to the bottom I can still feel that resistance.
In fact I can hold the fly wheel with channel locks and it will not spin over on its own.
Oh and I thought I was a little lean so I richened the high 2 and then 3 hours. Was not lean at all and had the tune nearly what I would call perfect.
Old 04-11-2010, 05:54 PM   #6
houston's Avatar
extechs are notorious for wearing out crankpins fairly quick , i would say you got good life out of the engine and its time for a new one . choose wisely as there are many great choices out there , you know my favorite engines
and you know joes favorite engines , you know ron hopkins favorite engines
some engines take more attention to detail and some just run no matter what you do to them . i would recommend OS or mugen nija engines for you personally .
are you going through plugs fairly quickly? can you feel rod slop?
Old 04-11-2010, 06:00 PM   #7
jpalessi's Avatar
see if it will "hold" compression... get the piston to top dead center androck teh flywheel back and forth w/o going below the ports. if you feel any blow by and the compression going down after just a couple "rocks" then its no good. just feeling the "pop" cold doesn't really mean the compression is good. also i would check and see how the bearings feel at bottom dead center... if it feels notchy or gritty its the bearing which wouldn't surprise me.
Joe Alessi
www.Lucky7RC.com
Old 04-11-2010, 06:13 PM   #8
dishsoap's Avatar
Why OS engines. Just curious. I heard they are hard to tune. Not going through plugs at all. Last one has a few race days on it and the one before that lasted over a gallon before I decided to just change it out just because.
I will try this once I get some time to pull it out.
I do want something that no matter what you do to it if just performs. Man the extech was really good to me but seems it would be a risk going with another one.
Old 04-11-2010, 06:26 PM   #9
jpalessi's Avatar
i would deff not go with another extech as the support isnt there like it was when we where doing them or even when chad was still there.. and much like our new engines (JS) a monkey could tune a OS.
Joe Alessi
www.Lucky7RC.com
Old 04-11-2010, 06:50 PM   #10
That's actually the exact opposite of OS engines. Like Joe said, a monkey could tune them.
As for your issue, if compression and tune are good the next things to look for would be a worn crank pin/rod bushing or gritty bearings. Both of which can cause an engine to flame out. I would also check the compression with the engine hot. Even heated up you should still be able to feel a little bit of a "pop".
-Koby Kubrin-
Engine Flaming Out Cory Kerber Nitro Off-Road 29 12-28-2009 09:35 AM
STS .28 pull-start engine dino.tw Onroad Nitro Engine Zone 632 08-31-2009 06:10 AM
AXE ROSSI COBRA X1 EVO ENGINE deeph Nitro Off-Road 25 06-23-2008 07:26 AM
Engine Tech x_man Malaysian R/C Racers 745 11-27-2007 11:05 PM
