Old 04-09-2010, 04:40 PM   #1
Default can you run a standard plug without the copper gasket?
just curious. what will happen?
"You are not understanding the fundamental principles of my fragmented personality"
Mugen
dreaux is offline   Reply With Quote
Old 04-09-2010, 04:42 PM   #2
JAMMINKRAZY's Avatar
Trader Rating: 17 (100%+)
NO!!! Absolutely not! The copper gasket is what seals a standard plug. Without it the plug will not seal at all.
-Koby Kubrin-
Thanks to my Sponsors:
Serpent America | Team Novarossi | Desoto Racing | Race AKA | Ridgeway Bodies
JAMMINKRAZY is offline   Reply With Quote
Old 04-09-2010, 04:50 PM   #3
i have a picco .26 i just rebuilt today. Got one of my old standard plugs and put it in. It would fire up and die after i took the ignitor off. Sometimes it would idle for a couple seconds and sometimes it would start screaming then die.
Then i remembered about the copper gasket. was hitting 200 at idle
got so used to putting turbo plugs in i forgot all about it
when smoke starting coming out the top i was like WTF?
thank god i figured it out after only half a tank
Mugen
Old 04-09-2010, 04:50 PM   #4
RC-ZOMBIE's Avatar
You won't even be able to tune it correctly.
Associated~Tekno~Mugen
RC-ZOMBIE is offline   Reply With Quote
Old 04-09-2010, 04:57 PM   #5
tune? it wont even run.
when i put the plug in the button head i remember saying at the time "man that plug sure is far into the combustion chamber". Duh duh duh.
I kept puting shims in. Had like 4. Started to get a little better
Mugen
Old 04-09-2010, 05:01 PM   #6
Moderator
J.Whiting's Avatar
Location: a very small town in wisconsin that is in the middle of absolutely no where
Trader Rating: 57 (100%+)
the copper shim does 2 things.....
1) seals the combustion chamber
2) shims the plug up high enough to clear the piston and centers the heat in the middle of the chamber...
jeremy
Jeremy Whiting - serpent america - desoto racing - apicco race engines - RcRenew - jconcepts - Rc Pro Products - ko propo eurus - ko propo servos - VP PowerMaster Fuels - Answer-rc usa - advantage racing products - Parma/pse bodies - serpent 811 2.1 - 811t
J.Whiting is offline   Reply With Quote
Old 04-09-2010, 05:05 PM   #7
so how bad did i mess up my engine running it without the gasket? I did less then a tank.
Mugen
Old 04-09-2010, 05:09 PM   #8
RC-ZOMBIE's Avatar
It will run, just don't take your finger off the triger.
Old 04-09-2010, 05:09 PM   #9
You're fine dreaux. No harm done. The reason it wouldn't run right and smoked was because of it leaking around the plug. While it is true that the copper gasket raises the plug some, it really has no chance of hitting the piston even without a gasket. The head button/combustion chamber are shaped in a way that would make that impossible.
-Koby Kubrin-
Old 04-09-2010, 05:10 PM   #10
RC-ZOMBIE's Avatar
Put the shim in and test it. You should be fine.
Old 04-09-2010, 05:14 PM   #11
i will get a new plug tomorrow. Don't have any copper shims around for some reason. Been over a year since i ran a standard plug.
Mugen
Old 04-09-2010, 05:17 PM   #12
by the way, what is a good standard O.S. plug? it will be for a ofna picco .26 outlaw.
Mugen
Old 04-09-2010, 05:27 PM   #13
None actually. OS plugs are short plugs. That engine accepts a long body plug. I would look at an Odonnell or McCoy plug or something along those lines. Maybe a novarossi plug. Say a #5 ultra plug. Or you could go with a picco plug like the Ofna #6(warning, they are expensive but last a long time).
Edit: you may be able to get the OS LC3 "long" plug to work. It's their only long plug and is a bit hot for that engine IMO.
-Koby Kubrin-
Old 04-09-2010, 05:34 PM   #14
Can we nominate most helpful poster? You should be a moderator jammin.
BTW, i am thinking about getting a LRP .30 It has 4.21 horses and 39K rpm's
not really gonna get it eerrr maybe
Mugen
Old 04-09-2010, 05:40 PM   #15
Aw shucks
LOL about the .30. Hahaha.
More like 2 hp and 20K rpm(if that)
-Koby Kubrin-
