Old 04-08-2010, 10:02 PM   #1
Default vspec question
whats up, ive got a vspec in my buggy and the fuel line tip is facin the wrong way, i took one of the little washers out(the botom one) and screwed it in by hand and it looks like when i tighten it down it will be facing just right,does anyone know if i tighten it down will it mess anything up in the carb? its not bottoming out in the carb, its still tightens on the tip. thanks for lookin!
vida is offline   Reply With Quote
Old 04-08-2010, 10:12 PM   #2
ScottyM's Avatar
Trader Rating: 27 (100%+)
You need to put the washer back in.. It will leak if you don't.. The fitting (called a Banjo fitting) will rotate. You just need to loosen the housing around the High Speed needle, and then rotate the banjo in the direction you want it, then retighten.. See the flat spots on the brass piece? That is what you loosen, then you can rotate the fuel nipple anywhere you want it.
Scott Musgrave
ScottyM is offline   Reply With Quote
Old 04-08-2010, 10:12 PM   #3
Racecrafter's Avatar
Trader Rating: 25 (96%+)
The "washer" is a gasket. You need to reinstall that. The banjo fitting (the piece with the nipple that the fuel line attaches to) will swivel, all you have to do is loosen the main housing (the one you removed) and turn it where you want it. Hold the nipple in place while gently snugging it back down as it is brass and will break if over tightened.
Jimmy Wright
www.trackstarrc.com ~ www.facebook.com/TrackStarRC ~ Home of the 2x's Stock Nationals Champion TS-Gold & TS-Black tire sauce, TS-1+ lubricants, TS-Precision bearings, XRG Xtreme Racing Grease, Scale Auto Engineering, ElevenTech, WRD2, Carbon 12, Stiff Products
Racecrafter is offline   Reply With Quote
Old 04-08-2010, 10:13 PM   #4
Beat me to the "submit" button
Jimmy Wright
Old 04-08-2010, 10:25 PM   #5
ScottyM's Avatar
Yeah I was quick on the draw with this one..
Scott Musgrave
Old 04-08-2010, 10:28 PM   #6
is that a coated crank i see on the limited edition???
that is one fine looking cooling head.
"You are not understanding the fundamental principles of my fragmented personality"
Mugen
dreaux is offline   Reply With Quote
Old 04-08-2010, 10:28 PM   #7
Trader Rating: 21 (100%+)
and DO NOT over stress the soft nickel gasket it will flatten out and start leaking.
TopGearRC is offline   Reply With Quote
Old 04-09-2010, 02:45 AM   #8
LabRat99's Avatar
I'm pretty sure the Limited are standard v-specs. The only differences are the head and the number etched into the side of the mounting boss.
LabRat99 is offline   Reply With Quote
Old 04-13-2010, 08:58 PM   #9
thanks guys, i accually called a friend and he said the same thing, didnt even think about that lol but yes that is a limited ed. the motor i was talkin about is the exact same thing, model # 006! love this motor, cools so much better than my reg vspec
my ninja/vspec experiment, you might be surprised! dreaux Offroad Nitro Engine Forum 227 04-22-2013 10:57 AM
O.S. Vspec Question Twisted Nitro Nitro Off-Road 17 11-01-2009 09:54 AM
