Old 04-08-2010, 07:53 PM   #1
Dlewis4's Avatar
Trader Rating: 148 (100%+)
Default Novarossi carb oring kit=REX Oring kit???
I am new to nitro, so i dont know what brnad is who/what/crosses.
I THINK Rex and NOvarossi are the same...correct?
I have a GO 7 port motor with a REX carb, and it is missing the oring on the bottom end needle, so i was just going to order a carb o ring kit.
Will http://www.amainhobbies.com/product_...F-BS-21SB-528X
work?
If not... where should i look?
Dlewis4 is offline   Reply With Quote
Old 04-08-2010, 08:10 PM   #2
Dlewis4's Avatar
anyone have any idea?
Old 04-08-2010, 08:14 PM   #3
JAMMINKRAZY's Avatar
Trader Rating: 17 (100%+)
Yes REX is a brand of Novarossi. As to whether or not that o-ring kit will work with your carb, I have no idea. That would probably depend on which version REX carb you have. Maybe Houston can provide some help if he sees this.
-Koby Kubrin-
Thanks to my Sponsors:
Serpent America | Team Novarossi | Desoto Racing | Race AKA | Ridgeway Bodies
JAMMINKRAZY is offline   Reply With Quote
Old 04-08-2010, 10:26 PM   #4
mblgjr's Avatar
Trader Rating: 86 (100%+)
Novarossi used to mfg. engines under the Novarossi, Top and Rex nameplates.
The carbs were often the same between them, though there were minor differences.
Chances are *real* good though that the O-ring kit you picked will work fine.
Team Associated Reedy JConcepts.net FusionX USA
mblgjr is offline   Reply With Quote
Old 04-08-2010, 11:35 PM   #5
Roelof's Avatar
Send a message via ICQ to Roelof
Maybe you have got a set from an older 4 screw carb...
Then there are some larger O-rings included for the rear (brass) LSN.
Speed is only fiction but a 130+km/h MRS4 is for real.
Roelof is offline   Reply With Quote
