best truggy tire >
best truggy tire
best truggy tire
Old 01-01-2010, 09:25 PM
Trader Rating: 30 (100%+)
Default best truggy tire
i am getting a rc8t for this season, was wondering what is generally the most run truggy tire on dry track from loose dry to blue groove. Whats a couple of the most popular tread patterns and compound
gofast072 is offline
Old 01-01-2010, 09:32 PM
vypr2002's Avatar
I like aka I beams, cityblocks, and the tried and true proline crimefighters
vypr2002 is offline
Old 01-01-2010, 09:35 PM
losi_racer's Avatar
Trader Rating: 25 (100%+)
Calipers, bowfighters(bowties in rear, crimefighter in front)and city block
losi_racer is offline
Old 01-01-2010, 09:49 PM
i was thinking calibers and city blocks but what compounds do i use for what tracks
Old 01-01-2010, 09:51 PM
imaxx21's Avatar
imaxx21 is offline
Old 01-01-2010, 09:57 PM
Frank L's Avatar
Trader Rating: 148 (100%+)
AKA Grid irons Soft or Super Soft if its cold outside, they hook up the best I have ever seen when the track is blue groove and hard packed. The track you are describing I would use cityblocks or caliber's
Frank L is offline
Old 01-01-2010, 10:04 PM
jmaxey51's Avatar
i have been running holeshots in the rear and bowties in the front and it has been working great. also ran the stock losi tires and they have been good too.
jmaxey51 is offline
Old 01-01-2010, 10:16 PM
ok 90 degrees outside the track is blue grooved, what tire would you use?
say its 80 degrees tracks a little loose hard and dry what tire would you use?
Old 01-02-2010, 06:02 AM
coaltrain's Avatar
You can almost get the JConcepts blue Crosshairs to work anywhere. Probably the best all around tire available.
coaltrain is offline
Old 01-02-2010, 08:14 AM
Racecrafter's Avatar
Trader Rating: 25 (96%+)
City Blocks or Grid Irons depending on the abrasiveness of the track.
Compound depending on the temp.
Racecrafter is offline
Old 01-02-2010, 08:20 AM
KIK
KIK's Avatar
Trader Rating: 26 (100%+)
I run crimefighters or Cityblocks in med. compound. Also like cityblocks up front and I beams in the rear if I need the rear to rotate around more.
KIK is offline
Old 01-02-2010, 08:22 AM
j_blaze14's Avatar
Trader Rating: 34 (100%+)
+1
j_blaze14 is offline
Old 01-02-2010, 08:32 AM
Trader Rating: 53 (100%+)
Take a look at the Gator and Raptor from Panther.
janderson78 is offline
Old 01-02-2010, 08:52 AM
Frank L's Avatar
Either caliber m2 all the way around or city blocks front and ibeams rear (both in soft) I like the calibers on almost every surface except indoor all clay.
Frank L is offline
Old 01-02-2010, 09:11 AM
Integra's Avatar
Citi Beam combo works awesome when new....but once the Citi's fall off the combo starts to hurt you more then help.
I really like Caliber's on certain tracks unfortunately they don't last terribly long.
Integra is offline
