Old 04-05-2010, 07:16 PM   #1
Default What colour should engine internals be?
I opened up my nova and the conrod and case are a copperish / brass colour. Is this ok? Or is it ment to be like new?
Inertia is offline   Reply With Quote
Old 04-05-2010, 07:19 PM   #2
Depends on fuel a lot. Sidewinder will dye it pink, Byron will give it a bit of an orange, I think O'Donnell will give it a bit of a brassy/yellow colour.
I have an RB that drank 8 gallons of Byron 30% and it's definitely orange inside.
Team HRC Raceway - http://www.hrcraceway.ca/
Semple is offline   Reply With Quote
Old 04-05-2010, 07:21 PM   #3
ok good. I thought it was corroding or rusting Cool thanks for clearing thta up
Old 04-05-2010, 07:28 PM   #4
Stubbs's Avatar
Trader Rating: 57 (100%+)
As long as it's not black, you're reasonably good to go. If it's black, that likely means the motor was run WAY too hot...the black usually comes from the oil in the fuel burning off before it reaches the combustion chamber.
Mike Stubblefield - www.capefearraceway.com
"If you're not racing to have fun, then you're doing it WRONG."
"All you need is WD-40 and Duct Tape. If it moves, and it shouldn't, use the Duct Tape. If it doesn't move, and it should, use the WD-40."
Stubbs is offline   Reply With Quote
Nirto off road fuel? GHETTOTEACHER Nitro Off-Road 31 09-26-2007 06:32 PM
