Old 04-07-2010, 08:20 AM   #16
Jaz240's Avatar
Trader Rating: 52 (100%+)
Originally Posted by Greenlee37 View Post
which gear are you running in your active? I was running the 43, just switched to a 41 on a team driver reccomendation.... not sure I like it.. 41 seems to make the car push coming out of corners... I didnt notice that prob when I had the 43 on.. Just seeing what everyone else is running... Im still on the 09 spec car..
I am using the 43 tooth on the original 808 (08) version. My set up is a combination of box stock and Rocco's starting set-up but with 35 front and 30 rear oil. silver springs, 5 hole rear pistons. stock sway bars. The thing with me though is that I take almost all my turns off power, because I still am a sucky driver so I roll most of my turns. The diffs free up so much off power that the car will turn on a dime. I would imagine that the more power you take into and during your turns the less stearing you will have, as that is the whole premise of the active diff
nothing to see here................................
Jaz240 is offline   Reply With Quote
Old 04-09-2010, 01:25 AM   #17
I think thath I should change tires - I use hammers - just check on google- couse I can't add urls, and I think that it's not good for clay and hard track. Maybe I should buy hole shots? Smth from proline? Thanks for help.
I've changed diff oils to 3/5/2 and it's really better but not perfect.
Our poish champ said that it's propably tires.
So my question is what tires buy?
Mateusz Purgal is offline   Reply With Quote
Old 04-11-2010, 10:35 PM   #18
merdith6's Avatar
Default Diff burninnnn
Too light on the diff oil. You will shorten the life of those diffs.....5-7-3.
Mad Dog drives a Mugen MBX-7, Novarossi engines, Clockwork Racing, Futaba radio, AKA/Proline Tires
merdith6 is offline   Reply With Quote
Old 04-12-2010, 09:54 AM   #19
but if it good drive? Are you sure that it's to light? But i think that 5/7/3 there is to big difference between front and rear
Old 04-12-2010, 12:31 PM   #20
merdith6's Avatar
Default Hmmm
the front takes a lot of power under acceleration due to the weight transfer, and the center takes a beating. 5-7-4 maybe. I just know that on every car I've built for me or friends loves 5-7-3. Even 6-7-4, is good. If you like it then that's the most important thing....Happy driving....
New XRAY 808 Philipm Nitro Off-Road 12372 12-08-2015 06:43 AM
Xray 808 E-Conversion Kit? Dookiman Electric Off-Road 467 04-26-2013 02:42 PM
808 or MBX6 and their driving styles/handling Chris-s Nitro Off-Road 75 02-18-2009 10:27 PM
Is your Xray 808 a P.O.S.? Toycar5 Nitro Off-Road 44 07-29-2008 10:50 AM
