Old 04-03-2010, 07:33 PM   #1
Default anyone ever mix and match P/S sets?
i have 2 worn out P/S sets. But when i swap the pistons they have a pretty good fit.
Is it possible for this to work? I don't see why not. It can see it will have really good compression, maybe even pinch but have not installed them yet.
but has anyone ever tried this?
And to be more acurate i have a sleeve that is less worn the fits really well with a piston from a completely worn out sleeve.
"You are not understanding the fundamental principles of my fragmented personality"
Mugen
dreaux is offline   Reply With Quote
Old 04-03-2010, 07:42 PM   #2
Slider30250's Avatar
Well it is the piston that wears faster than the sleeve, that's why ultimately why sleeve pinching works. You're shrinking the sleeve down to the size of the piston. If the fit is right it should work just fine, I would run that motor rich for two or three tanks to be safe.
Anyone can crash, I crash with style
Mugen MBX6R/Airtronics M11X/Ninja Engines/Sidewinder Fuel/EB Mods
Slider30250 is offline   Reply With Quote
Old 04-03-2010, 07:54 PM   #3
kaptain crash's Avatar
Trader Rating: 32 (100%+)
Send a message via Yahoo to kaptain crash
yeah, give it a try cant hurt much.
YEAH IM OLD...RUSTY AND SLOW,CRASH A LOT TOO. BUT WITH NITRO I HAVE A BLAST!
kaptain crash is offline   Reply With Quote
Old 04-03-2010, 08:05 PM   #4
jmaxey51's Avatar
like what is the worst that could happen, it not work? or it blow? well if blows its like oh well it was two worn out engines anyways. i took a C6 that hade a ruined crank case and put it in a GRP crank case that had a bad rod, crank, and piston/sleeve. it ran ok i actually ran it at the track one day, but it blew at the house when i was trying to get some more bottom out of it, i just laughed and said oh well atleast i tried to make a running engine out of two broken ones.
jmaxey51 is offline   Reply With Quote
Old 04-03-2010, 08:18 PM   #5
houston's Avatar
Trader Rating: 91 (100%+)
Don't tell any body but all my race engines are rematches
As long they are in good shape with no scratching you will be fine , just don't get it too tight I can tell you that from experience yes
TEAM FUSION X ENGINES / TEAM BYRON ORIGINALS / TEAM PROLINE RACING TIRES / TEAM SICK GRAPHICS /TEAM KYOSHO / things I support: COMP HEAT DEALER /TEAM LUNSFORD/ FUSIONX™ USA / TEAM KYOSHO / "H.E.S."™ / BYRON FUELS / RC-OMGUSA/KICWEBDESIGNZ/AKA TIRES/PROLINE RACING TIRES /RAYA RACING/BUKU POWER CLUTCH/M2CRACING/special thanks to STAV and JIM HOTTIGREENMOUNTAINGRILLS.COM
houston is offline   Reply With Quote
Old 04-03-2010, 08:19 PM   #6
I see houston eyeing this up.....he would be the guy to comment on this ...like to hear his input on this one.
Old 04-03-2010, 08:23 PM   #7
JAMMINKRAZY's Avatar
Trader Rating: 17 (100%+)
Agreed! I only wish you could buy pistons separately. Hell you could probably get a couple rebuilds out of one sleeve if you could put new pistons in it.
So yeah dreaux, you can do that just fine! But be careful like Monty said. You don't want to get it too tight! That can cause some problems.
-Koby Kubrin-
Thanks to my Sponsors:
Serpent America | Team Novarossi | Desoto Racing | Race AKA | Ridgeway Bodies
JAMMINKRAZY is offline   Reply With Quote
Old 04-03-2010, 08:27 PM   #8
Well im glad of that, just gave a younger just getting into 1/8 buggy my old GO 5port and with my sleeve and piston out of a 7 port ...same year...told him he should be able to swap if he needed a 7 port for his buggy but wasent 1oo% sure.
Old 04-03-2010, 09:06 PM   #9
i have another odd question. If you are looking through the exhaust port and watching the piston go up sleeve you see a couple tiny bubles just for a second. is that normal? I hardly ever look through the exhaust port anymore. I has a crap ton of compression, but maybe they have scratches?
Mugen
Old 04-03-2010, 09:48 PM   #10
that's normal. It's just oil bubbling.
-Koby Kubrin-
Old 04-03-2010, 10:15 PM   #11
22Racer's Avatar
Trader Rating: 67 (100%+)
I've have mixed piston and sleeve sets for a while. I also have the tools to expand a sleeve to fit a piston that is bigger. I still charge the same as pinching a sleeve. ($15.00)
Rex
Rw modding and engine repair http://www.rw-mods.com
Sleeve resizing $15.00/ motor rebuild $30.00
Argus engine distributor/Avid bearings/ Alpha engines/
Fx Royal engines/ Maxy Engines
e-mail rwmods@yahoo.com Rex Welch
22Racer is offline   Reply With Quote
Old 04-03-2010, 10:54 PM   #12
thanx jammin. I thought so.
If you only knew what i really did. But i will never tell
Mugen
Old 04-04-2010, 02:13 AM   #13
Roelof's Avatar
Send a message via ICQ to Roelof
If the engines are bought at the same time you can give it a try. If not then there is a chance different materials are used and so the expansion rate of the piston and sleeve would not match.
I have played with it in the past but the results were mostly a bad running engine or a fast wear on the piston. You will be more save with pinching with the result you will have 2 working P/S sets
Speed is only fiction but a 130+km/h MRS4 is for real.
Roelof is offline   Reply With Quote
Old 04-04-2010, 07:27 AM   #14
lanmine657's Avatar
I swapped p/s on an old sportwerks.26 It was real tight, so I re-broke the motor in. Ran it on the rich side for the first gallon but as soon as I got it leaned out(240 range), it shot the rod out the side of the case. To me it was funny as hell and it made real cool sound when it blew. If i was to do it again I would go with pinching.
lanmine657 is offline   Reply With Quote
Old 04-04-2010, 09:14 AM   #15
houston's Avatar
First of all you must make sure you have a piston from another p/s set that is the same as what you are rematching to. You can't take a novarossi piston and put it in an OS engine or whatever ( btw that would never work and was thrown out ther just for example )
I rematch from novarossi , almost all the pistons are the same aside from a few engines that have different bore/stroke ratios . If done properly this method yields the perfect p/s set , trust me .
I am in no way telling you guys to go out and rematch until your hearts content but never be afraid to try something if you think its logical .
