what do u think losi 8 t 1.0 with 2.0 body
so i picked up a 2.0 body cheap modified it and custon fit it to my 1.0
it was real easy took off my rear body mounts and in the bottom of my shock tower above the rear diff the body mount had to be cut down but it fit dead center of the rear of the body. had to trim a little off the rear but it worked does a 2.0 shock tower bolt up to a 1.0 diff
Very nice paint job. The lid looks great.
Did you reposition the rear body mounts somehow? I cant tell what is holding the rear of the body secure from the picture. Looks good though
losi body
what i did was took off the rear body mounts and each body mount had 2 holes for mounting screws. i cut the lower hole off so it only had one screw mount right obove the rear diff in the 1.0 shock tower there is a hole that i mounted it to so the rear only has one mount position in the rear dead center
You could also put the 2.0 rear body mounts on in the same manner as you have done with the 1.0 mounts, it worked great for mounting a Proline Bulldog body on mine.
how did u do double mounts? i have one single mount
used the two holes dead center of the shock tower above the diff
and cut down a 1.0 body mount did u drill holes in ur tower and use 2.0 mounts? or is that a 2.0 shock tower?
and what brand wing is that does it work good looks agressive
What did you do on the Front body mount's ? just flip them around and oval out the holes ?
